Question [Solved] plg_kunenatoolbar: Parse error: syntax error,
16 years 7 months ago - 16 years 7 months ago #38156 by Tariqa2009
any idea what is this error i cant login to admin setting of kunena
Parse error: syntax error, unexpected $end in /home/techhom1/public_html/rt/administrator/components/com_kunena/toolbar.kunena.php on line 92
Last edit: 16 years 7 months ago by sozzled. Reason: Change topic title
16 years 7 months ago - 16 years 7 months ago #38157 by Tariqa2009
<?php /** * @version $Id: toolbar.kunena.php 502 2009-03-06 18:05:01Z fxstein $ * Kunena Component * @package Kunena * * @Copyright (C) 2008 - 2009 Kunena Team All rights reserved * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @link http://www.kunena.com * * Based on FireBoard Component * @Copyright (C) 2006 - 2007 Best Of Joomla All rights reserved * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @link http://www.bestofjoomla.com * * Based on Joomlaboard Component * @copyright (C) 2000 - 2004 TSMF / Jan de Graaff / All Rights Reserved * @license http://www.gnu.org/copyleft/gpl.html GNU/GPL * @author TSMF & Jan de Graaff **/ // ################################################################ // MOS Intruder Alerts defined( '_JEXEC' ) or die('Restricted access'); // ################################################################ require_once( JApplicationHelper::getPath( 'toolbar_html' ) ); switch ($task) { case "new": case "edit": case "edit2": CKunenaToolbar::_EDIT(); break; case "cancel": CKunenaToolbar::DEFAULT_MENU(); break; case "showconfig": CKunenaToolbar::_EDIT_CONFIG(); break; case "showCss": CKunenaToolbar::CSS_MENU(); break; case "profiles": CKunenaToolbar::_PROFILE_MENU(); break; case "instructions": break; case "newmoderator": CKunenaToolbar::_NEWMOD_MENU(); break; case "userprofile": CKunenaToolbar::_EDITUSER_MENU(); break; case "pruneforum": CKunenaToolbar::_PRUNEFORUM_MENU(); break; case "syncusers": CKunenaToolbar::_SYNCUSERS_MENU(); break; case "showAdministration": CKunenaToolbar::_ADMIN(); break; case "showprofiles": CKunenaToolbar::_PROFILE_MENU(); break; case "showsmilies": CKunenaToolbar::_SHOWSMILEY_MENU(); bre
Last edit: 16 years 7 months ago by Tariqa2009.
16 years 7 months ago #38158 by Tariqa2009
ok i worked it out guys thanks this code was missing from the file that installed on the server which is
ak; case "editsmiley": CKunenaToolbar::_EDITSMILEY_MENU(); break; case "newsmiley": CKunenaToolbar::_NEWSMILEY_MENU(); break; case "ranks": CKunenaToolbar::_SHOWRANKS_MENU(); break; case "editRank": CKunenaToolbar::_EDITRANK_MENU(); break; case "newRank": CKunenaToolbar::_NEWRANK_MENU(); break; default: CKunenaToolbar::BACKONLY_MENU(); break; } ?>
I think lots of people going to have this error the file script not complete hope this will help other to solve this issue copy this replace it thanks
16 years 7 months ago #38201 by sozzled
???? Sorry, I've never encountered this situation in any version of Kunena. :huh:
16 years 7 months ago #38207 by LittleJohn
Can you reproduce this error if you uninstall joomla and kunena and start all over again?
Which versions are you using (of Joomla, Kunena, apache, PHP, Mysql, O/S, etc)?
When I cut the script at your position, the file is exactly 2048 b long.
How is this relevant?
It COULD be some defective buffer or errors in installation, but it could also just be a coincidence...
16 years 7 months ago #38245 by JerryLeeLewis
had this problem too thanks for it
Time to create page: 0.254 seconds
