Question Upgrade to 1.5.7 from 1.5.5
16 years 5 months ago #34116 by MJW
I would like to upgrade to your new 1.5.7 from 1.5 but please could you confirm, will I lose all the postings on the current board when I uninstall the current Kunena? Many thanks
16 years 5 months ago #34118 by xillibit
You lose anything because all datas (users, posts, categories, ...) are saved in the database. Read this doc : docs.kunena.com/index.php/Upgrading_to_l...t_Kunena_1.5_release
For reminder, you have just to install the version of kunena that you want without uninstall the previous version, all is done automaticly.
16 years 5 months ago #34120 by MJW
Replied by MJW on topic Re:Upgrade to 1.5.7 from 1.5.5
Hello, Many thanks for your reply especially so very quickly. I had taken a look at the instructions and thought I needed to uninstall the older version first. However I have now tried to install the new version without first uninstalling the old one and I get this message "BZip2 Not Supported". Have I done something else wrong?
16 years 5 months ago - 16 years 5 months ago #34121 by xillibit
Try install with kunena archive in .zip or in tar.gz
If you want bzip2, you need to enable in your php extensions the module : php_bz2
Last edit: 16 years 5 months ago by xillibit.
16 years 5 months ago #34138 by MJW
Thank you, that did it. Can I ask another question though. I have Jomsocial on my website too. How can I get Jomsocial integrated with Kunena the way you have done, my two components do not interlink although I can now with this new version of Kunena use the PM facility to go to the message box in Jomsocial for which I thank you very much.
16 years 5 months ago #34142 by xillibit
You can do it, in joomla! backend in kunena configuration panel, you have three options : avatar integration, profile and private messaging; which can be integrated with joomsocial.
