Question 1.5.7 upgrade: Fatal error: require_once() in bankend
- SlowSteady
- Junior Member
16 years 5 months ago - 16 years 5 months ago #33850
by SlowSteady
1.5.7 upgrade: Fatal error: require_once() in bankend was created by SlowSteady
I upgrade from 1.5.6 to 1.5.7 and all appeared to go fine until I tried to go to Kunena admin in the backend. I get this error:-
I then uninstalled Kunena and tried with another download, this time using the tar.gz version instead of the .zip version. Still the same problem.
How to solve please?
NOTE:- Using ...
- Joomla 1.5.15
- JomSocial 1.6.254
Warning: require_once(/home/xxxxx/public_html/administrator/components/com_community/libraries/core.php) [function.require-once]: failed to open stream: No such file or directory in /home/xxxxx/public_html/plugins/community/system.php on line 10
Fatal error: require_once() [function.require]: Failed opening required '/home/xxxxx/public_html/administrator/components/com_community/libraries/core.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/xxxxx/public_html/plugins/community/system.php on line 10
NOTE:- Using ...
- Joomla 1.5.15
- JomSocial 1.6.254
Last edit: 16 years 5 months ago by SlowSteady.
16 years 5 months ago #33902
by Matias
Replied by Matias on topic Re: 1.5.7 upgrade: Fatal error: require_once() in bankend
You're using beta version of JomSocial, which didn't have updated versions of their plugins. We had the same issues, but they were fixed by installing a new version of JS.
- SlowSteady
- Junior Member
16 years 5 months ago - 16 years 5 months ago #33974
by SlowSteady
Replied by SlowSteady on topic Re: 1.5.7 upgrade: Fatal error: require_once() in bankend
So you're saying if I go back to the stable version (1.5.248 instead of 1.6.xxx) of JS it should work?
I'll try this.
I'll try this.
16 years 5 months ago #33983
by Matias
Or later unstable version. We have Version: 1.6.254, which contains new versions from most plugins.
- SlowSteady
- Junior Member
16 years 5 months ago #34008
by SlowSteady
That's the version I'm using ... see my first post.
16 years 5 months ago #34034
by fxstein
Replied by fxstein on topic Re: 1.5.7 upgrade: Fatal error: require_once() in bankend
If you are running the JS 1.6 Beta you MUST upgrade the plugins to the latest version. All of them are no longer compatible and will throw that fatal error, since JS integration is part of the backend to test if it exists, any installed JS plugins will throw that error. We too are running a JS Beta here but have requested the updated plugins, that solved that issue.
Hope this helps!
Hope this helps!
Time to create page: 0.223 seconds
