Question Install Problem
17 years 3 weeks ago #32179 by jdln
Install Problem was created by jdln
When I try and install kunena with joomla I get a blank page. Im running MAMP on my localhost. I know this can be to do with my php.ini file but ive had this problem tying to install other programs into joomla and havnt managed to fix it.
Whats worked before is changing my PHP from version 5 to 4, installing the program, and then changing the PHP version back to 5. However when I try and install kunena while running PHP version 4, I get this message;
I N S T A L L : F A I L E D - Minimum Version Requirements not satisfied
php version: 4.4.8 (Required >= 5.0.3)
mysql version: 5.0.41 (Required > 4.1.19)
Does anyone know of a solution? Can I do a manual installation?
17 years 3 weeks ago #32189 by xillibit
Replied by xillibit on topic Re:Install Problem
Firstly you need to use php 5.0 and secondly try to enable debug mode in joomla configuration panel.
17 years 3 weeks ago #32190 by jdln
Replied by jdln on topic Re:Install Problem
With php 5 I get a blank page so no debug information.
I dont know if it will be helpful but this is the debug info from my extension manager page.
thanks
•Profile Information• Application afterLoad: 0.003 seconds, 0.33 MB Application afterInitialise: 0.077 seconds, 2.36 MB Application afterRoute: 0.077 seconds, 2.36 MB Application afterDispatch: 0.113 seconds, 4.17 MB Application afterRender: 0.164 seconds, 4.86 MB •Memory Usage• 5141456 •12 queries logged.• 1. SELECT * FROM jos_session WHERE session_id = '44bacac3e93bbf9822dce232480423f4' 2. DELETE FROM jos_session WHERE ( time < '1256933767' ) 3. SELECT * FROM jos_session WHERE session_id = '44bacac3e93bbf9822dce232480423f4' 4. UPDATE `jos_session` SET `time`='1256934667',`userid`='62',`usertype`='Super Administrator',`username`='admin',`gid`='25',`guest`='0',`client_id`='1',`data`='__default|a:8:{s:15:\"session.counter\";i:8;s:19:\"session.timer.start\";i:1256934532;s:18:\"session.timer.last\";i:1256934612;s:17:\"session.timer.now\";i:1256934624;s:22:\"session.client.browser\";s:100:\"Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10.5; en-US; rv:1.9.1.3) Gecko/20090824 Firefox/3.5.3 GTB6\";s:8:\"registry\";O:9:\"JRegistry\":3:{s:17:\"_defaultNameSpace\";s:7:\"session\";s:9:\"_registry\";a:2:{s:7:\"session\";a:1:{s:4:\"data\";O:8:\"stdClass\":0:{}}s:11:\"application\";a:1:{s:4:\"data\";O:8:\"stdClass\":1:{s:4:\"lang\";s:2:\"en\";}}}s:7:\"_errors\";a:0:{}}s:4:\"user\";O:5:\"JUser\":19:{s:2:\"id\";s:2:\"62\";s:4:\"name\";s:13:\"Administrator\";s:8:\"username\";s:5:\"admin\";s:5:\"email\";s:34:\"[email protected]\";s:8:\"password\";s:65:\"a1d2b59388f399e143717f0d16531584:1nFJ4b8S42MSTbMHgtH1j5KAtvWtAxZO\";s:14:\"password_clear\";s:0:\"\";s:8:\"usertype\";s:19:\"Super Administrator\";s:5:\"block\";s:1:\"0\";s:9:\"sendEmail\";s:1:\"1\";s:3:\"gid\";s:2:\"25\";s:12:\"registerDate\";s:19:\"2009-10-30 11:19:37\";s:13:\"lastvisitDate\";s:19:\"2009-10-30 14:11:26\";s:10:\"activation\";s:0:\"\";s:6:\"params\";s:70:\"admin_language=en-GB\nlanguage=en-GB\neditor=none\nhelpsite=\ntimezone=0\n\n\";s:3:\"aid\";i:2;s:5:\"guest\";i:0;s:7:\"_params\";O:10:\"JParameter\":7:{s:4:\"_raw\";s:0:\"\";s:4:\"_xml\";N;s:9:\"_elements\";a:0:{}s:12:\"_elementPath\";a:1:{i:0;s:87:\"/Users/jameschetwood/Sites/communitybuilderdata/libraries/joomla/html/parameter/element\";}s:17:\"_defaultNameSpace\";s:8:\"_default\";s:9:\"_registry\";a:1:{s:8:\"_default\";a:1:{s:4:\"data\";O:8:\"stdClass\":5:{s:14:\"admin_language\";s:5:\"en-GB\";s:8:\"language\";s:5:\"en-GB\";s:6:\"editor\";s:4:\"none\";s:8:\"helpsite\";s:0:\"\";s:8:\"timezone\";s:1:\"0\";}}}s:7:\"_errors\";a:0:{}}s:9:\"_errorMsg\";N;s:7:\"_errors\";a:0:{}}s:13:\"session.token\";s:32:\"0cd88cf3a86160a4e3f93a58d55d5106\";}' WHERE session_id='44bacac3e93bbf9822dce232480423f4' 5. SELECT folder AS type, element AS name, params FROM jos_plugins WHERE published >= 1 AND access <= 2 ORDER BY ordering 6. SELECT * FROM jos_components WHERE parent = 0 7. SELECT template FROM jos_templates_menu WHERE client_id = 1 AND menuid = 0 8. SELECT id, title, module, position, content, showtitle, control, params FROM jos_modules AS m LEFT JOIN jos_modules_menu AS mm ON mm.moduleid = m.id WHERE m.published = 1 AND m.access <= 2 AND m.client_id = 1 ORDER BY position, ordering 9. SELECT a.*, SUM(b.home) AS home FROM jos_menu_types AS a LEFT JOIN jos_menu AS b ON b.menutype = a.menutype GROUP BY a.id 10. SELECT * FROM jos_components WHERE `option` <> "com_frontpage" AND `option` <> "com_media" AND enabled = 1 ORDER BY ordering, name 11. SELECT COUNT(*) FROM jos_messages WHERE state = 0 AND user_id_to = 62 12. SELECT COUNT( session_id ) FROM jos_session WHERE guest <> 1 •Language Files Loaded• * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.plg_system_debug.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_installer.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.tpl_khepri.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.mod_submenu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.mod_title.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.mod_toolbar.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.mod_menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_comprofiler.menu.ini * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_contact.menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_kunena.menu.ini * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_poll.menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_search.menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_banners.menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_newsfeeds.menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.com_weblinks.menu.ini 1 * /Users/jameschetwood/Sites/communitybuilderdata/administrator/language/en-GB/en-GB.mod_status.ini 1 •Untranslated Strings Diagnostic• •None• •Untranslated Strings Designer• •None•
17 years 3 weeks ago - 17 years 3 weeks ago #32200 by xillibit
Do you have read this doc : docs.kunena.com/index.php/Installation_Issues ?
Try to install from a directory.
Last edit: 17 years 3 weeks ago by xillibit.
17 years 2 weeks ago - 17 years 2 weeks ago #32391 by silviu
Replied by silviu on topic Re:Install Problem
Hi, i have this error
-1 - An error has occurred.It was not possible to copy the selected file.
when i want to instal kunena.
But this component appears as if the tables were installed in jos_fb .... in the database and folder com_kunena the components on the host.
What would be the solution?
Thanks!
Last edit: 17 years 2 weeks ago by silviu.
17 years 3 days ago - 17 years 3 days ago #33093 by mumins
Replied by mumins on topic Re:Install Problem
The same problem
I uninstall 1.5.4, then install 1.5.7. (com_kunena_v1.5.7_stable_b1851_2009-11-18.zip ) through Upload Package File.
FreeBSD/Apache/J1.5.14 permissions/max uplad size/memory limit/safe mode off/ ok
Joomla show Kunena in Extension Manager Kunena - 1.5.7 2009-11-18 www.Kunena.com
but i'm not sure that it's true.
Last edit: 17 years 3 days ago by mumins.
