Important How Do I Embed Kunena?
17 years 4 months ago #23297 by Rezzin
Hi, I would like to embed a forum into my site the same as this site tinyurl.com/n3edl7 using Kunena on ning'ssite. Is there a simple way to do this and what steps to install Kunena.
Thanks,
Rezzin
17 years 4 months ago #23307 by fxstein
Replied by fxstein on topic Re:How Do I Embed Kunena?
When you say embed. What do you mean?
Kunena is always embedded in Joomla. Depending of your Joomla template choice and the variation of module positions, the forum will be an integrated part of your site.
Simply install the component and configure Joomla to your likings.
Hope this helps!
fxstein
17 years 4 months ago #23316 by Rezzin
Replied by Rezzin on topic Re:How Do I Embed Kunena?
Thanks fxstein. I am a newbie and I am not familiar with Joomla. I am reading up on Joomla as we speak. I would just like to have a forum put into my website. Where do I start? What do I need to download or install. If you have a few steps that would be great.
Thanks.
17 years 4 months ago #23317 by 810
17 years 4 months ago #23377 by Rezzin
Thanks 810. I have read all the info. so I have a basic Idea but still a little stuck on how to get started. Do I download Joomla first and upload it to my webhost? or do I just download Kunena and upload that to my webhost? Then how do I get the results similar to this site here? tinyurl.com/n3edl7
Thanks Again.
17 years 4 months ago #23401 by 810
Replied by 810 on topic Re:How Do I Embed Kunena?
First you upload the files "Joomla 1.5.12" to your webhosting. then install joomla, and config the site. then remove the installation map. Go to your site anysite.com/administrator, login. go to extensions. install. And then click on browse. get the package off kunena and clik on install.
