Question Error when converting from phpBB to Kunena
15 years 1 month ago - 15 years 1 month ago #91833 by frold
Hey,
I try to use this guide
docs.kunena.org/index.php/PHPBB3_to_Kunena
I did clean up my database using the STK package from phpBB
www.phpbb.com/support/stk/
Did download the convert file.
When I try to run that one I get this error:
Importing data from phpBB Connecting to Database... OK Populating Categories... OK OK Populating Messages Table... Invalid query: INSERT INTO `joomla15`.`jos_fb_messages` (id, ip, phpbb_userid, userid, name, time, thread, subject, hits, catid, parent) VALUES ('31267', '0.0.0.128', '1', '1', 'Kommende PDA'er', '1042401177', '31267', 'Ipaq 3835', '601', '1082', '0') You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'er', '1042401177', '31267', 'Ipaq 3835', '601', '1082', '0')' at line 1
The fireboard stats says:
Topics: 980
Users: 1
phpBB says:
Replies 46766
Topics 7294
Users: 8408
What a mess...!!
Last edit: 15 years 1 month ago by frold. Reason: wrong link to STK
15 years 1 month ago - 15 years 1 month ago #91837 by frold
Okay I did manually edit all
"Kommende PDA'er"
to
"Kommende PDAer"
Now it seems to work!
15 years 1 month ago - 15 years 1 month ago #91840 by frold
Hmmm
I did get this error:
Fatal error: Maximum execution time of 60 seconds exceeded in C:\Documents and Settings\idi4eh\Skrivebord\xampp\xampplite\htdocs\joomla15\converter\go.php on line 281
to solve that I did
FIND
ini_set("magic_quotes_gpc", "1"); set_magic_quotes_runtime ( 0 );
AFTER ADD
set_time_limit(180);
and now my output ends with
OK
Complete... :lol:
15 years 1 month ago #91851 by frold
When trying to upgrade using Joomla 1.5 (newest) and Fireboard 1.0.4 to Kunena 1.6.3 I get this error:
Fatal error: Class 'KunenaFactory' not found in C:\Documents and Settings\idi4eh\Skrivebord\xampp\xampplite\htdocs\joomla15\administrator\components\com_kunena\install\upgrade\upgrade-1.6.0_configuration.php on line 17
15 years 1 month ago #91859 by frold
frold wrote: When trying to upgrade using Joomla 1.5 (newest) and Fireboard 1.0.4 to Kunena 1.6.3 I get this error:
Seems to be solved by this post: www.kunena.org/forum/173-k-16-installati...factory-class-solved
15 years 1 month ago #91885 by xillibit
Try by uninstalling previous version and install the new one
Time to create page: 0.295 seconds
