Question How to integrate Kunena with Groupjive?
17 years 3 months ago - 17 years 3 months ago #27353 by mortenrasmussen
I have installed Groupjive (the latest B4) and Kunena (also the latest 1.5.5).
But I can't figure out how to integrate these. In the integrate tab i GJ theres a "Show forum" option, but I can't see what effect it actualy has.
I just want the registered members of my CB to be able to create forums when they manage a GJ-group. Or maybe just by default in group-creation.
Anyway: Im pretty lost and need some take-off-help :huh:
Thanx, Morten
Last edit: 17 years 3 months ago by mortenrasmussen.
17 years 3 months ago #27394 by Matias
You should enable CB integration in Kunena and try again. Forums will be created only after you have enabled the support.
17 years 3 months ago - 17 years 3 months ago #27401 by mortenrasmussen
Where should I enable CB?
On the configuration/integration-tab I have chosen CB for avatar and profile. These are the only two options with relation to CB.
Is there another place I have to enable CB to get Kunena to work with Groupjive?
17 years 2 months ago #27670 by cristopher
Hello!
I am also trying to integrate Kunena with Groupjive. In the groupjive website, there is a demo there showing the integrated version of the Kunena with GroupJive, can anybody tell us how is this done? Where will we enable the CB from Kunena? The only CB in the integration part is for the profile and avatar.
Please help.
Thanks,
Cris
17 years 2 months ago #27720 by crackersandmilk
i am interested too
17 years 2 months ago #27882 by Matias
You need to enable full CB integration in order to integrate with GroupJive. Nothing else will be needed in K1.5.5+..
