Question Sticky vs Spotlight
16 years 5 months ago #48509 by kiwi3685
Sticky vs Spotlight was created by kiwi3685
Apologies if this has been asked before. I did search but didn't find it. :unsure:
Is there some logic to why Kunena has an option to "Make sticky", but it results in creating a "Spotlight"? Seems to me the entire reason why there are a number of queries here about not being able to find "Sticky" posts!
Can I recommend the two words are made the same - either both Sticky or both Spotlight, please. Much less confusing.
In the short term, can someone point me to where I can change "Spotlight" to "Sticky" on my site - it would save a lot of hunting around. B)
16 years 5 months ago #48519 by Cerberus
Replied by Cerberus on topic Re: Sticky vs Spotlight
In long term:
This has been corrected in the uncomming K1.6 its something that start back in Fireboard and has never been changed.
In short term:
id would try looking in the language file
16 years 5 months ago #48556 by kiwi3685
Replied by kiwi3685 on topic Re: Sticky vs Spotlight
Thanks, found the entry to change.
Out of interest, which solution does 1.6 use, both "Sticky" or both "Spotlight"?
16 years 5 months ago #48560 by sozzled
Replied by sozzled on topic Re: Sticky vs Spotlight
In K 1.6 the moderator command is "sticky" (or "unsticky"). In the version of K 1.6 that I've been testing I haven't found the word "Spotlight" yet. I haven't really looked into this all that much.
16 years 5 months ago #48654 by @quila
Replied by @quila on topic Re: Sticky vs Spotlight
In the k 1.6 table header with a word "Spotlight" is just remouved (default template).
15 years 11 months ago #71178 by FreeThinker
Replied by FreeThinker on topic Re: Sticky vs Spotlight
Hi all
where can we change / alter the colf a sticky topic!?
example:
