Kunena 6.2.6 released
Question Login Problems [SOLVED]
I am using kunena and CB. I have disabled joomla registration (only registration through CB) and my login links all go through the CB login module.
However, the "login" and "register" links at the top of kunena still point to the default joomla pages. So, when you click Login in kunena it brings you to /user/login
and when you click register it comes back with an error page (because i turned off joomla registrations.
How can I get these two links in kunena to use the CB pages? I already have CB integration set in the kunena settings.
Even though I have all community builder integration turned on, there is no place to change where the login and register links point. They seem to be hard coded to the joomla pages.
I hope there is a setting in the backend that lets you specify a url or something. that would be great.
Easiest way to get URLs to work is to disable integration detection -- for now.
Go to components/com_kunena/lib/kunena.communitybuilder.php line 76 and add:
to the first line of that function.
- flashgetpro
