This is not a support forum for Community Builder or its related products. For Community Builder support you should visit Joomlapolis .
The information given in this category is intended to guide users who want to use Community Builder with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of Community Builder.
Solved Why is Kunena setting my users as administrators when they register?
12 years 5 months ago - 12 years 5 months ago #156517 by GODpleasers
:dry: Any ideas of why kunena forum is setting new users up as administrators automatically after they register? Any solution's?
heres our kunena report...
Joomla! SEF: Disabled | Joomla! SEF rewrite: Enabled | FTP layer: Disabled |
htaccess: Exists | PHP environment: Max execution time: 120 seconds | Max execution memory: 512M | Max file upload: 200M
Joomla default template details : beez3 | author: Angie Radtke | version: 3.1.0 | creationdate: Unknown
Third-party components: CommunityBuilder 1.9.1 | UddeIM 3.4
Plugins: None
Modules: Kunena Stats 3.0.1 | Kunena Login 3.0.1
Last edit: 12 years 5 months ago by GODpleasers.
12 years 5 months ago #156518 by 810
please add kunena report
12 years 5 months ago #156520 by GODpleasers
Plugins: None
12 years 5 months ago #156522 by 810
Try change some kunena plugins
Kunena - AlphaUserPoints Enabled: activity=1 avatar=0 profile=0 activity_points_limit=0
Kunena - Community Builder Enabled: access=1 login=1 activity=1 avatar=1 profile=0 private=0
Kunena - JomSocial Enabled: access=0 login=0 activity=0 avatar=0 profile=0 private=0 activity_points_limit=0 activity_stream_limit=0
12 years 5 months ago #156523 by GODpleasers
12 years 5 months ago #156524 by 810
The following user(s) said Thank You: billvv
Time to create page: 0.174 seconds
