This is not a support forum for JomSocial or its related products. For JomSocial support you should visit JomSocial .
The information given in this category is intended to guide users who want to use JomSocial with Kunena and, mostly, was written by Kunena users. The information here is not necessarily accurate, up-to-date nor is it intended to replace the support given by the developers of JomSocial.
Solved [SOLVED] when click menu "500 - JDatabaseMySQL::query: 1146"
12 years 11 months ago - 12 years 11 months ago #151308 by ae3d
SOLVED - look here for solution ( mine anyway )
man im losing my head on this one
I am building a new site. While i was building over the past year (its not public yet)
there was an Upgrade to Kunena so i installed that
Now running K 3.0.3 Ill paste the report below
Well i noticed that once the upgrade completed, if i clicked on my FORUM menu item in the MAIN MENU i get a 500 error screen
so i turned on DEBUG MODE for K!
It showed me there was a module conflicting with K! so i uninstalled that module.
The module most likely did NOT work with this verion of K!.
Not a problem.... in the end, if i have to install an older version of K! then i will but for now, each time i click my menu item for K! i get the 500 error screen
Once the module was removed, i get this
JDatabaseMySQL::query: 1146 - Table 'db33727_tuu.gruv_components' doesn't exist SQL=SELECT id from gruv_components WHERE link = 'option=com_community' and enabled='1'
ok says the component is not there. yes it is
So i removed the menu item and then created a new one (Forums) with a new alias.
I still get the same error
something is blocking K! and i cant find it
here we go: REPORT
htaccess: Exists | PHP environment: Max execution time: 500 seconds | Max execution memory: 99M | Max file upload: 50M
Joomla default template details : Hardcore | author: JoomlaXTC | version: 1.0.0 | creationdate: Unknown
Kunena version detailed: Kunena 3.0.3 | 2013-10-20 [ Bifrost ]
Third-party components: Jomsocial 2.8.3
Plugins: JomSocial - My Kunena Forum Menu 2.0.3 | JomSocial - Kunena Groups 2.0.3
Modules: Kunena Latest 3.0.1
Last edit: 12 years 11 months ago by ae3d.
12 years 11 months ago - 12 years 11 months ago #151311 by Mortti
Check that your database tables is not corrupted...
Interesthing name of table???
Last edit: 12 years 11 months ago by Mortti.
12 years 11 months ago #151317 by xillibit
You need to update jomsocial and all his plugin, i remember to have seen this issue in the past
12 years 11 months ago #151365 by ae3d
xillibit wrote: Hello,
ya know what, would believe this is the problem.
Because i had Kunena installed already on this site, for the past year with Jomsocial and they were connected to eachother
again this site is NOT public, there are no members, its still in development
this probme didnt arrise until i did a backup reinstall of the site which came shortly after doing an upgrade of Kunena to v3.0.3
This site is bascially a copy of my radio station so right now im going to go to THAT site and check
What version Kunena is running on the radio station
What version Jomsocial is running on the radio station
What versions of the Jomsocial modules are running on the station
Ill do a little comparison but again, if i need to downgrade to a previous version of Kunena.... i really have no problem doing that
12 years 11 months ago #151366 by ae3d
not sure if this will help any but
i did a comparison bewtween the two websites
they both have all the same items , modules, component versions installed
one website is working fine but there is something else i noticed.
on the site where i am having a problem with Kunena
i went to my Jomsocial profile there.
There is a KUNENA updates that should show on my profile
and instead of showing my posts in Kunena it says
" Kunena is not installed. Please contact site administrator. "
Ok so Jomsocial says Kunena is NOT installed.... well its possible its not installed completely during upgrade so can agree to that. Because i cant even get to it directly.
ok so now what?
all the versions are the same on both websites
12 years 11 months ago #151367 by Jiminimonka
I do not think that JomSocial 2.8 is compatible with Kunena 3. You might have to contact the developers at Jomsocial for confirmation of that. As xillibit wrote earlier, you will have to update JomSocial to the latest version.
Please read the FAQ.
Only one question per topic.
Time to create page: 0.160 seconds
