Question Frontend language doesn't agree with Joomla settings
7 years 9 months ago #208444 by tcn
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 8M
Joomla default template details : astroid_template_zero | author: JoomDev | version: 2.0.2 | creationdate: Nov 2018
Kunena default template details : Crypsisb3 | author: Kunena Team | version: 5.1.9 | creationdate: 2019-02-15
Kunena template params:
Kunena version detailed: Kunena 5.1.9 | 2019-02-15 [ Kerberos ]
Third-party components: UddeIM 4.0
Plugins: None
[hr]
Our Joomla configuration is set to show content in Dutch (NL-nl) for the frontend. However, in my profile I see quite a lot, but not all, navigation links and buttons displayed in English. I already checked my settings in Kunena and Joomla. Both are set to use Dutch. In our test environment everything was working well regarding language settings.
What am I missing?
7 years 9 months ago #208445 by rich
Have you installed the newest Kunena language package too?
7 years 9 months ago #208446 by tcn
Neither site has any Kunena language packs installed. So why does it work out of the box on one site and not on the other?
7 years 9 months ago #208447 by rich
The Kunena installation package contain since many years only the English language. For another languages you must install the language package. Maybe your pages contain still the language from old Kunena versions. The language files will not deleted if you update Kunena but the files are out of date.
7 years 9 months ago #208448 by tcn
Fine. I'll install the required language pack. Yet, the question remains, how come it works on one site but not on the other? Or, let me rephrase, how do I determine what language packs are installed?
From my perspective it looks like both sites (test & production) are identical with respect to Kunena.
7 years 9 months ago #208449 by rich
I'm sorry, but I can't know it. Maybe you use a Kunena 3rd party template with own language folder, or you've tested Kunena many years ago? In very old Kunena versions was all languages included and it was not needed a extra installation. Check the folder /language/nl-NL whether you find any ini files which beginning with nl-NL.com_kunena.
If you has installed the language package, you see this in the extension manager (as in the image which you've posted).
Time to create page: 0.167 seconds
