Solved [CRITICAL BUG] Reproducible Problem after Upgrading Kunena 4.0.5 to 4.0.6
I am a new user here. First of all I had issues to create an account because it seems that not only GMX Email is troubling as described on the register page but also outlook.com does not receive any confirmation emails. Please delete my duplicate accounts alQamar, alQamar2 after investigating why those email adresses have not received any confirmation emails. Thanks in advcance.
Regarding my Kunena Problem:
I have made a backup of my IIS and SQL before I have updated from Kunena 4.0.5 to 4.0.6 using the backend of Joomla.
The upgrade of Kunena, incl. german language pack and some other kunena related packages ran with no error!
However everytime after I have updated from 4.0.5 to 4.0.6 I see that there is a severe problem with my forum. As far as I can see this is caused by the module "Kunena Latest".
Instead of my usual homepage I got only 2 ascii characters displayed. When I deactivate the module Kunena Latest my Joomla webpage is operational but I cannnot access anything related kunena related with the same error.
Used Browser is Firefox currently 41.0.1, which is also used by the majority of our visitors.
However when I downgrade to 4.0.5 the error is gone. This error is reproducible each time I upgrade to 4.0.6. I have waited for a patch / hotfix in the last weeks after Kunena 4.0.6 was published but so far there is none available that is also recognized by the autoupdating feature.
Tried measures so far:
- Purging caches in Joomla
- purging browser cache
- repair Kunena menu
- checking for Joomla / Database errors
nothing of that helped to solve the issue.
Here is my configuration report:
The used template is Crypsis 4.0.6
This is the first time I am running into troubles, that cause an inoperable site / forum after updating Kunena. So far I was very happy with the smooth and hassle free updates since 4.0.
Thanks for any help / hint in advance.
in order to receive a solution please drop me a line. Thank you very much again.
- coder4life
- Kunena Contributor
- Thank you received: 50
It is also possible to run the upgrades again from the Joomla backend by re-uploading the appropriate package and see if the upgrade completes correctly. Some servers in general sometimes have an issue and do not completely correctly.
Also make sure to disable any integration plugins with other software, sometimes they create issues with newer version of Kunena.
Hope that helps to give you an idea where to look and steps to try.
rich wrote: Have you installed Admin Tools? Please read this post .
Yes I am running Admin Tools 3.6.3, do you think I should disable them?
The are not linked on the forum / Joomla webpage.
sorry, I am not using MS SQL but MySQL. Webserver is indeed IIS and running fine with 4.0.5. I will try to download the package manually and install it again via the Joomla backend.
edit: I have manually downloaded and successfully reinstalled all Kunena Components:
www.kunena.org/download
pkg_kunena_v4.0.6_2015-09-28
pkg_kunena_languages_v4.0.6_2015-09-28
mod_kunenalatest_v3.1.1.1_2015-09-28
mod_kunenalogin_v3.1.1_2015-09-28
mod_kunenasearch_v3.1.1_2015-09-28
mod_kunenastats_v3.1.1_2015-09-28
plg_content_kunenadiscuss_v3.1.1_2015-09-28
plg_search_kunena_v3.1.1_2015-09-28
tmpl_kunena_crypsisb3_v4.0.6_2015-09-28
Hence nothing changed Still just see this ASCII chars on my webpage, perhaps try it your own: www.gamez-clan.de
I can 100% reproduce that Kunena Latest 3.1.1.1 is causing the issue. As soon I disable it, the forum and Joomla webpage works again.
Any ideas?
Find the Kunena modules and plugins attached.
Can-you set on "Maxmimum" the setting Errors reports in tab server in Joomla configuration panel ?
Do-you see an error now when you have the Kunena latest enabled ?
Here is the output, in addition to these ASCII characters:
Notice: Undefined property: KunenaTemplateCrypsis::$ktemplate in C:\Server\Webpage\gamez-clan-30\libraries\kunena\template\template.php on line 804
Notice: Trying to get property of non-object in C:\Server\Webpage\gamez-clan-30\libraries\kunena\template\template.php on line 804
Fatal error: Call to a member function get() on null in C:\Server\Webpage\gamez-clan-30\libraries\kunena\template\template.php on line 804
I think this refers to the Crypsis Template.
