configuration report
Question Xmap Site Map Kunena and OSMAP
- thomasmanca
- Topic Author
9 years 4 weeks ago - 9 years 4 weeks ago #1
by thomasmanca
Xmap Site Map Kunena and OSMAP was created by thomasmanca
Hello. I learned today that the component Xmap ended to exist !!
On the official website is written: "Xmap is finally gone! Xmap is not longer supported nor available, go to Joomla's Extension Directory to look for alternatives. "
I read on the web that the Xmap component does not work on joomla 3.4
The component OSMAP seems to have taken the place of xMAP www.alledia.com/extensions/osmap/
Installing OSMAP you can import the configuration of Xmap and all pluigin of Xmap work in OSMAP ... including Plugin XMap for Kunena ..
Last edit: 9 years 4 weeks ago by thomasmanca.
- coder4life
- Kunena Contributor
- Thank you received: 50
9 years 4 weeks ago - 9 years 4 weeks ago #2
by coder4life
Replied by coder4life on topic Xmap Site Map Kunena and OSMAP
Hello thomasmanca,
We unfortunately do not have control over XMAP and although we would like to help with your problem, we really cannot provide help for something we have no control or detailed knowledge of.
I suggest contacting the authors of the application at the URL you specified in your post. They will understand the structure of the data stored in that extension.
Wish the best of luck, have a good day.
Last edit: 9 years 4 weeks ago by coder4life.
- thomasmanca
- Topic Author
9 years 3 weeks ago #3
by thomasmanca
Replied by thomasmanca on topic Xmap Site Map Kunena and OSMAP
Hello coder4life.
Thanks for the answer but you did not understand !!
I have no problem !!
I just wanted to inform Xmap that no longer exists and that in its place instead OSMAP works very well with Kunena !!
- coder4life
9 years 3 weeks ago #4
by coder4life
Ah ok, sounded like a question at first, but I see the bottom sentence is just a statement. My bad, thanks for the heads up.
8 years 11 months ago #5
by djb
Replied by djb on topic Xmap Site Map Kunena and OSMAP
I installed OSMap 3.1.2 on J3.4 and K3.0.7 two days ago. I also enabled the OSMap Kunena plugin 3.1.0. While the base OSMap is working for me, the Kunena plugin is not currently picking up any forum information.
The problem is with OSMap and a solution is awaited. This is for information only.
Time to create page: 0.517 seconds
