configuration report
Question Main menu for Kunena not staying highlighted
11 years 5 months ago #160396
by mdraeger
Main menu for Kunena not staying highlighted was created by mdraeger
I installed Kunena and the main functionality works great. However, the active view in the main menu does not react correctly. Inactive state is the correct color, hover works fine, but when I select the forum main item, and I go to the forum main page, the forum menu item goes back to an inactive state.
Any idea why this is happening? See attached. The Forum main menu button should stay red (active)when I am on the main forum page.
All other menu items are working correctly.
11 years 5 months ago #160397
by mdraeger
Replied by mdraeger on topic Main menu for Kunena not staying highlighted
New to forum so didn't realize I need configuration details.
So here they are.
Template using JSN Force Pro - latest version
Joomla 3.3
Kunena 3.0.6
So here they are.
Joomla 3.3
Kunena 3.0.6
11 years 5 months ago #160402
by 810
Replied by 810 on topic Main menu for Kunena not staying highlighted
i don't see the attachment. please add the kunena report here.
11 years 5 months ago #160414
by mdraeger
now with attachment. basically, it doesn't stay red when I select the forum menu
11 years 5 months ago #160415
by 810
this is a flaw in Kunena, i never found a solution for it, because we are loading a other menu: kunenamenu, so the template doesn't know that the forum item is still active.
regards 810
regards 810
11 years 5 months ago #160417
Replied by sozzled on topic Main menu for Kunena not staying highlighted
According to Matias, it's a defect in Joomla menu system.
Time to create page: 0.266 seconds
