Solved Where is "More Smileys"?
12 years 3 months ago #153243 by MadJosch
I am using Kunena 3.0.4 on my website and added some more smilies via backend. But now as the limit of 20 smilies in the toolbar is reached, the rest won't be displayed. In the wiki and other posts in the internet i found that there should be a "More Smilies" button. But it isn't there (or I am too blind to see it).
How do I display more than 20 smilies or at least the "More Smilies" button?
12 years 3 months ago #153252 by sozzled
Replied by sozzled on topic Where is "More Smileys"?
G'day, MadJosch, and welcome to Kunena.
The "more smileys" feature was removed in K 1.6 (3+ years ago). There are no plans to re-instate this feature.
12 years 3 months ago #153253 by MadJosch
Replied by MadJosch on topic Where is "More Smileys"?
In other words, this means additionally to the already available smilies there are only 3 custom ones possible?
12 years 3 months ago #153262 by sozzled
MadJosch wrote: In other words, this means additionally to the already available smilies there are only 3 custom ones possible?
No, that is not correct. I have a forum where I have 29 smileys available (and displayed on the screen so that my users can select them) - no "More Smileys" button, of course - so there is not this kind of limitation.
It's a little complicated to explain, perhaps, but the information is documented (maybe not in the easiest to read way) in Smiley management in the Wiki. the trick is check the Emoticon Bar checkbox.
Does this help?
The following user(s) said Thank You: MadJosch
12 years 3 months ago #153264 by MadJosch
Thanks, I thought I did tick the box but obviously I didn't :whistle:
That did the trick for the ones not showing.
10 years 8 months ago #168422 by virtinsanity
So was there any workaround created by the community to have "more smileys" button in kunena or are we all alone.
Why i want this feature is because wheneer you try to use the post panel when writing on mobile phones if you have more smileys than the default then the panel is mixed up with smileys so fe. you can't use insert link etc. etc.
I apprecaite if you lead me to any workaround been made.
