Solved K 2.0.2, K 2.0.3: problems with preview
11 years 6 months ago #21 by pequeno74
Preview doesn´t work for me too.
I have two websites with kunena 2.0.2. In one works and another does not.
I tested with default joomla template and does not work.
11 years 6 months ago #22 by sozzled
What are the differences between your two sites - the one where the preview works and the one where the preview does not? Are they hosted on the same platform? Do you have a different mixture of software components? When you identify the key difference(s) then you are well on the way to resolving the problem.
The following user(s) said Thank You: pequeno74
11 years 6 months ago #23 by pequeno74
Hello sozzled
They are hosted in the same platform - No platform problem.
They have different templates, but the problem occurs with joomla default tempalte too - No joomla template problem.
I'm testing the different components
11 years 6 months ago #24 by pequeno74
SOLVED.
In my case, I inserted code in kunena.php that caused the problem.
Delete the code and works fine.
11 years 6 months ago #25 by roland_d_alsace
pequeno74 wrote: SOLVED.
Hi pequeno.
Can you say more ?
What code have you deleted in kunena.php (have you made a downgrade of kunena.php in 2.0.1) ?
Have you the same ajax problème like me html return instead of json ?
Thanks.
Regards.
11 years 6 months ago #26 by freedomcoach
This issue of your preview remaining blank may be more revealing than meets the eye. I suggest that you do an experiment. Open the preview window before typing your message, then start typing slowly and see if the preview window slowly catches up.
If and when you see the preview go blank try saving your post and see what happen. You may get an error message saying your message box is blank when you know that it isn't. If this occurs, we will finally have someone experiencing the same issue I have posted here that no one is responding to.
Sozzled, please do not consider this post off topic, it is not. There is relevance here worth some investigation!
11 years 6 months ago #27 by 810
I found a bug in a Phoca plugin. So if you are using that, the preview breaks.
If you don't use that plugin. Please typ the plugins that are you using.
regards 810
11 years 6 months ago #28 by pequeno74
Hi pequeno.
Can you say more ?
Thanks.
Regards.
Sorry, I had problems with my internet connection.
Have you made changes to kunena.php? If so, try one without change.
I don´t know what my problem was.
In my kunena.php, before
<?php
I put a text with <h2> label.
11 years 6 months ago #29 by deltafidesign
When I click on the preview button it opens the box but no message is shown. Why?
11 years 6 months ago #30 by xillibit
Replied by xillibit on topic No preview for messages
Maybe because you have a plugin or javascirpt which conflicting with it.
Time to create page: 0.596 seconds
