Important K 1.5 latest posts module - no longer supported or maintained. Do NOT use this with K 1.6!
Yes, it's the case. I need this, until stable version will be out. Then we could support only from stable version up and we don't need to detect changed API, so I can revert it back, for use under PHP 4.3+.Just want to confirm this will not work with PHP 4x? I hope that's not the case.
Actually I am not sure if it doesn't work under PHP 4.3, but I think Reflection class is new in PHP 5.
If you are not using svn version, you can revert back to version 1.0.29. But I think stable version will be out in the following days, so it will be OK.
- johnnydement
- Elite Member
- I'm back
Also notice that php4 is going to be deprecated soon, you should ask your ISP for upgrade
Kunena 1.0.x works in PHP 4.3+.
!works only from kunena 1.0.8 stable up!
docs.kunena.com/index.php/Technical_Requ...PHP4_Compability_Fix
Well I don't know about state of Joomla 1.0.x compatible Kunena Latest Module. Can somebody give me a picture of current state? I think it could be easily possible to port my Kunena Latest to Joomla 1.0.x.Someone asked a few weeks ago if there would be a version compatible with Joomla! 1.0.x. The only response was "Upgrade!" so I'll ask again
And I hear your voice, backported module for Joomla 1.0 :woohoo:Someone asked a few weeks ago if there would be a version compatible with Joomla! 1.0.x. The only response was "Upgrade!" so I'll ask again
HaND
