Question New topic icons display in a column not in a row...
12 years 2 months ago #1 by jcrimmel
I am running Kunena 1.7 on Joomla 2.5.1 and the new topic icons are shown in one column rather than in a row. Is there a simple way to change this?
Thanks,
Jason
12 years 2 months ago - 12 years 2 months ago #2 by sozzled
I have no idea how to help you because you have not given us any information.
I think you should read My Joomla template is making a mess of Kunena . I also think you should read the posting guide printed at the top of this page. Perhaps, after we have some basic information about your website (e.g. your configuration report would help) we could better understand your problem. I think your problem is caused by your Joomla site template. I'm guessing.
It would also help if you posted a screenshot to show what is happening at your website.
If, in order to test the issue at your site, we require an account can you please post a test account for us to use. You can do that by using the
Last edit: 12 years 2 months ago by sozzled.
12 years 2 months ago #3 by jcrimmel
Report:
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 256M | Max file upload: 64M
Joomla default template details : skylab | author: LineLab.org | version: 1.0.0 | creationdate: 9.1.2012
Third-party components: AlphaUserPoints 1.7.1 | Jomsocial 2.4.2
Modules: Kunena Latest 1.7.1 | Kunena Stats 1.7.1 | Kunena Login 1.7.1 | Kunena Search 1.7.1
Image:
12 years 2 months ago - 12 years 2 months ago #4 by jcrimmel
www.thebrokenovary.com
Last edit: 12 years 2 months ago by jcrimmel.
12 years 2 months ago #5 by sozzled
12 years 2 months ago #6 by jcrimmel
sorry forgot to enable it.
12 years 2 months ago #7 by sozzled
I will have a look at this tomorrow when you have an account that works.
12 years 2 months ago #8 by jcrimmel
The username is working fine now.
12 years 2 months ago #9 by sozzled
I found out what was causing the problem. Your Joomla site template CSS (/templates/skylab/css/styles.css) has the following rules (at around line 447):
div.component input, div.component select, div.component textarea {
background: -moz-linear-gradient(center top , #F1F1F1, #FFFFFF) repeat scroll 0 0 transparent;
border: 1px solid #DCDCDC;
display: block;
margin-bottom: 10px;
padding: 3px;
input, select, textarea {
display: block;
padding: 3px;
If you comment-out the lines I've highlighted in red, your site will work fine. For some unknown reason, the template designer decided to make a mess of things. I think you should complain to your template designer.
12 years 2 months ago #10 by jcrimmel
Thank you. That worked perfectly. I will definitely contact the template author.
thanks
Time to create page: 0.591 seconds
