- Thank you received: 566
Question Multilingual LTR and RTL sites. Load different kunena.forum.css files for each language
Yes, $this->language does not exist in Kunena 1.5 context.
I believe that you need to detect language because of RTL? This is how you do it.
Matias, I can't describe in words how much I thank you!Matias wrote: I didn't check the code, I just corrected the bugs in it.
Code:$lang = JFactory::getLanguage(); if ($lang->isRTL()) { $document->addStyleSheet(KUNENA_DIRECTURL . '/template/default_ex/rtl.css'); } else { $document->addStyleSheet(KUNENA_DIRECTURL . '/template/default_ex/ltr.css'); }
Works perfectly!
Now hours of css tweaking
If someone provides us css file for RTL (preferably containing only changes to default css) I would be glad to add buildin support for RTL languages.
Matias, if I understood the code above will change the css depending on selected language (joomla), right? But, if I want to use the same css for both, but I just want to call a different forum structure (forum/posts/threads) for each language?
- ahmedfouad
RTL = right to left
LTR and RTL = the direction you read the word in
- ahmedfouad
Cerberus wrote: LTR = left to right
RTL = right to left
Ah, it's better now. :0) Thanks Cerberus for the explanation.
Have a nice Sunday.
JoomFish supports translating Kunena configuration. Luckily, one of these configurations is template name. I simply uploaded a localized template and named it "default-ar" went back to JoomFish, and translated the template name to my localized template. and Voila, it works like a charm.
is this code good for 1.6? and where to put this code in order to call the RTL in case of switching between RTL and LTR??
please advice,
Avi
