Question Add File not working with Firefox 18+
13 years 4 months ago - 13 years 4 months ago #139573 by Shimei
There are two things that I have done to rectify this issue. The first one was done awhile back when I updated the mootools.js file located in: /plugins/system/mtupgrade/mootools.js
The issues I had back then, was mainly with profiles not working correctly in various browsers, IE 9 comes to mind.
That file can be found here: Mootools.js.zip
Just replace it with 810's modified file.
The second step was to Add to that mootools.js file in plugins -- system -- mtupgrade:
String.prototype.contains = function(string, separator){ return (separator) ? (separator + this + separator).indexOf(separator + string + separator) > -1 : String(this).indexOf(string) > -1; };
I had the same issue with Firefox 18 until I made the last change. Now I am running Firefox 18.1. My site, Joomla! 1.5.26 and Kunena 2.04 (with either Tigra or default Blue Eagle) works without error utilizing this combination -- Check out the new Kunena 2.04 -- Blue Eagle and Yoothemes blending here: ReligiousVerse Forum
Hope this helps!
Last edit: 13 years 4 months ago by Shimei.
The following user(s) said Thank You: donkey12, Mikote, Bob Britt, Moonstone, senes, Smoker_Creep
The topic has been locked.
13 years 4 months ago #139581 by donkey12
Many thanks Shimei,
I am running a Joomla 1.5.26 site with a Gavik template and Kunena 2.0.3.
Hopefully that will be enough to solve the issue.
13 years 4 months ago #139698 by senes
Jiminimonka wrote: Please provide full information about your Joomla installation, including the version, and other extensions you are using.
I am using Kunena 2.0.3 with Joomla 1.5.26.
sozzled wrote: *** Topics merged ***
senes: I suggest that you very carefully read the last 9 messages posted in this topic before this message.
Sorry it was my mistake. I should read before writing :/
Shimei wrote: There are two things that I have done to rectify this issue. The first one was done awhile back when I updated the mootools.js file located in: /plugins/system/mtupgrade/mootools.js
Hope this helps!
Thanks! That solved my problem. In firebug I still get an error, but Spoilers an "Add-Image" works now : )
Yours sincerely
senes
13 years 4 months ago - 13 years 4 months ago #139861 by asusnet
Where exactly must write it???
Or you have any write file to send me???
Last edit: 13 years 4 months ago by asusnet.
13 years 4 months ago - 13 years 3 months ago #140719 by c_schmitz
Hi!
I have a clean Joomla 1.5 version (latest release, default theme) and installed the latest Kunena version on it. I have checked that the Mootols plugin is properly enabled.
I create a new post, key in some text, then I click the 'Add file' button and the file browser window opens just fine. I select a small file which has an allowed extension, and choose OK.
However the input field beside the 'Add file' button stays empty. On saving the new post there is no file attached.
Expected behaviour: After selecting a file the file path & name should be visible in the input field. On save the file should have been attached.
There are no JavaScript errors in the console nor are there any other errors shown.
I think it is a bug only happening with Joomla 1.5. Any help is appreciated greatly!
Best regards
Carsten
Last edit: 13 years 3 months ago by c_schmitz. Reason: Removed configuration data
13 years 4 months ago #140722 by rich
== Topics merged ==
You find the solution in this topic.
Time to create page: 0.283 seconds
