Important AUP and Kunena 1.6
15 years 1 week ago - 15 years 1 week ago #97756 by Ratisar1
AUP and Kunena 1.6 was created by Ratisar1
Hello, I have established Kunena 1.6.4 and AUP 1.6.1 on joomla 1.6.3
But when has established all options as was in the instruction but when the user writes messages points aren't charged.
And still I have noticed that there is no pair of points and the integration menu.
Namely switching-off of display of points and medals.
htaccess: Missing | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : yoo_planet | author: YOOtheme | version: 5.5.0 | creationdate: January 2011
Kunena default template details : InfinityHU | author: PedroHSI | version: 1.6.0 | creationdate: 2010-07-21
Third-party components: AlphaUserPoints: The file doesn't exist alphauserpoints.xml ! | UddeIm: The file doesn't exist uddeim.j15.xml !
Modules: Kunena Latest 1.6.4
In advance I change for transfer translated the translator.
Last edit: 15 years 1 week ago by sozzled. Reason: Reveal K 1.6 configuration report in message
15 years 1 week ago #98057 by xillibit
Replied by xillibit on topic Re: AUP and Kunena 1.6
I think you need to wait AUP 1.6.2 version because this version has some issues...
15 years 18 hours ago #98523 by Ratisar1
Replied by Ratisar1 on topic Re: AUP and Kunena 1.6
Clearly, with that that balls aren't charged I has reconciled.
Can then will prompt as to clean them in post display
Without cleaning thus a medal.
Earlier it was in the integration menu.
15 years 16 hours ago #98532 by Mortti
Replied by Mortti on topic Re: AUP and Kunena 1.6
Bernard Gilly is the developer of the AlphaUserPoints 1.6.1 (and any versions), Kunena Team has nothing to do of AUP points what it give (if we play integrations/API). There are some issues what not should be come if you installed that in some another language than english etc etc... I will try to inform to Bernard all of issues, but you have to remember that my free time is also limited! In English that should work almost fine, what I have tested. Upcoming AUP 1.6.2 will fix some problems on it...
15 years 6 hours ago #98571 by Ratisar1
But problems not in files AUP it in Kunena files
14 years 11 months ago #99792 by Dazhelpwiz
Replied by Dazhelpwiz on topic Re: AUP and Kunena 1.6
as posted in another thread:
as inelegant as it is I have a hack for this issue (AUP 1.6.1, Kunena 1.6.4, J1.6.4).
It seems as tho the AUP API is missing from the functions in kunena.
Find the file ./components/com_kunena/funcs/post.php.
Scroll down to protected function newtopic.
Now, just above this function is the tail end of the post function for posting your response/new topic.
change the following from:
if ($holdPost == 1) { $redirectmsg .= JText::_ ( 'COM_KUNENA_POST_SUCCES_REVIEW' ); } else { $redirectmsg .= JText::_ ( 'COM_KUNENA_POST_SUCCESS_POSTED' ); } $this->_app->redirect ( CKunenaLink::GetMessageURL ( $id, $this->catid, 0, false ), $redirectmsg ); }
to:
if ($holdPost == 1) { $redirectmsg .= JText::_ ( 'COM_KUNENA_POST_SUCCES_REVIEW' ); } else { $redirectmsg .= JText::_ ( 'COM_KUNENA_POST_SUCCESS_POSTED' ); $api_AUP = JPATH_SITE.DS.'components'.DS.'com_alphauserpoints'.DS.'helper.php'; if ( file_exists($api_AUP)) { require_once ($api_AUP); AlphaUserPointsHelper::newpoints( 'plgaup_kunena_topic_reply' ); } } $this->_app->redirect ( CKunenaLink::GetMessageURL ( $id, $this->catid, 0, false ), $redirectmsg ); }
unfortunately this will award the same points for a reply and new topic to whatever you have set in the reply rule.
Inelegent yes, but it works...
Time to create page: 0.272 seconds
