Important Problem with Latest Posts 1.6.4
15 years 5 months ago - 15 years 5 months ago #94302 by etkritikonspoudon
Thanks for updating this great little module...
I am having a small issue with it, however...it's a display issue:
When I first create/enable the module it shows correctly, but after I visit any other page, it becomes skewed
After I clean the cache, it is displayed correctly again...
Any ideas?
Thanks a lot
htaccess: Exists | PHP environment: Max execution time: 30M seconds | Max execution memory: 64M | Max file upload: 20M
Joomla default template details : rt_versatility4_j15 | author: RocketTheme, LLC | version: 1.5.4 | creationdate: August 20, 2010
Plugins: System - Mootools Upgrade: Enabled | System - Mootools12: Disabled | Kunena Search 1.6.2 | Kunena Discuss 1.6.4
Modules: Kunena Latest 1.6.4
Last edit: 15 years 5 months ago by etkritikonspoudon.
15 years 5 months ago - 15 years 5 months ago #94324 by etkritikonspoudon
I should add there, to make the report more descriptive for non-greek speaking users and to facilitate the issue's resolution for Kunena support, that in the above image the forum categories within which the posts have been created, show up in the same way as the posts/threads...moreover, as you can see there is a bullet point in front of the post time as well
Maybe there's something there, along with the caching of the module (no setting available to prevent it from caching and see if there is any difference.
15 years 4 months ago #97051 by John
Did you solve this problem? I have exactly the same problem...
15 years 4 months ago #97055 by Aalii
John,
The Kunena Latest module has option, to use your own css or the module's css. Use your own css, like this:
Copy the Kunena Latest module css and paste it to your template css, on top or bottom. Then in kunena latest module disable load module css. And it will use the css style in your template css.
This works until the module load css fixed.
15 years 4 months ago #97064 by etkritikonspoudon
Νο, unfortunately not...
John,
I will try this out and report back, thanks...
15 years 4 months ago #97175 by tread77
You can always use the 1.6.3 Latest posts module. It still looks good and works great with 1.6.4 without adding the extra bullets in front of the avatars.
Time to create page: 0.221 seconds
