Important [RESOLVED] Kunena Discuss 1500 posts in less than 2 seconds crashed site.
- Acapulco Kevin
- Junior Member
Recently I installed Joomla 1.7, JCE editor, Jomsocial 2.4, Kunena 1.7, Kunena Discuss 1.7 and nothing else. My server is operating perfectly, the site is working perfectly EXCEPT Kunena Discuss.
Initially, I left all Kunena settings at the default and tested Kunena Discuss and ended up with 2500 duplicate messages in the forum.
I now have configured Kunena Forum under the Integrations tab to use Jomsocial for everything except Access control and that is set to Joomla. Now kunena discuss generates this error on the very first comment:
* -post-: Duplicate. Identical message has been ignored.
* -load-: An invalid post ID was requested.
Message
* Your message has been posted.
The article is posted to the forum, there are no duplicates now but that message happens on every first comment. All subsequent comments post normally with no error message.
I would really like to solve this issue so I can proceed with setting up my site. I am willing to give Kunena developers access to my site so we can solve this issue. Obviously I am not the only person having issues with this.
- Acapulco Kevin
- Junior Member
- Acapulco Kevin
- Junior Member
The issue was JomSocial plugin that called onPrepareContent (Joomla! 1.5 event) inside onContentBeforeDisplay (Joomla 1.6+ event).
So this was what happened:
1) Kunena Discuss gets run on onContentBeforeDisplay event
2) Plugin notices that no topic exists and creates new one with content of: "[ article ]1234[ /article ]"
3) Topic creation triggers jomsocial activity stream integration and parses BBCode
4) Inside BBCode parser Kunena loads article and calls onContentPrepare event
5) JomSocial plugin turns this event into onPrepareContent (to make its legacy plugins to work)
6) Kunena discuss gets run on onPrepareContent event
7) Discuss goes to step 2 (indefinite loop)
There's a quick fix for this:
Edit /plugins/content/kunenadiscuss/kunenadiscuss.php and remove following lines near line 100:
- Acapulco Kevin
- Junior Member
Matias wrote: Finally with the great help of Acapulco Kevin I've managed to find out what's the issue was.
Edit /plugins/content/kunenadiscuss/kunenadiscuss.php and remove following lines near line 100:Code:// Joomla 1.5 support public function onPrepareContent(&$article, &$params, $limitstart=0) { $context = 'com_content.article'; return $this->prepare($context, $article, $params); } function onAfterDisplayContent(&$article, &$params, $limitstart=0) { $context = 'com_content.article'; return $this->display($context, $article, $params); }
Everything works perfectly now... Without the above fix... Data Base nightmare..
Much appreciated Matias.
I think since you found out that it's a jomsocial plugin that triggers it, they should do something about it.
Jus thinking out loud.
