- Thank you received: 4
Question RC 1.6 Mootools issue with JSN Epic Pro menu animation
I just upgraded my site to RC 2 from 1.5.12 and everything was fine.
Then I realised that my menues are mo longer flipping due to an updating problem with Mootools 1.2.
Is there any solution to have both working in parallel.
According to the JSN Epic (my Joomla template) changelog in version2 there is a Mootools 1.2 detecting implemented.
This is what I found on the JSN EPIC website:
"Currently, In JSN Epic version 3.6 lastest, we have added automatic detection of Mootool 1.2 Plugin and switching to javascript support for it. "
I am using this version (3.6).
Any hints?
If there is no solution how to rollback to 1.5.12? uninstall and reinstall 1.5.12?
Best regards
Onki
I already started a thread in their support forum. M;eanwhile I have to uninstall the RC2 since all mey menues are not working and only 20% of my websites are available.
Is it OK to uninstall RC2 and then reinstall 1.5.12 or will this give problems due to changes database structure?
Best regards
Onki
I uninstalled Kunena RC2 without installing the old version. Now the menus are working again. The mtupgrade plugin is still activated.
According to the Joomlashine forum the version 3.6 of my template (installed on my site) is compatible with MooTools 1.2.
What can I do. Who is causing this problem?
Best regards
Onki
