Question IE8 problems
15 years 8 months ago #84893
by nbserg
Replied by nbserg on topic Re: IE8 problems
15 years 8 months ago - 15 years 8 months ago #84959
Replied by sozzled on topic Re: IE8 problems
nbserg: I do not see these white spaces on the screen in IE8 as a guest. Can a guest see these white spaces on the screen or do you have to login first?
15 years 8 months ago #85049
by nbserg
login
i make forum tab plugin only for registers users
i can make for all if you have troubles with registration
15 years 8 months ago #85050
by 810
Replied by 810 on topic Re: IE8 problems
ok, here is some news about it (source:http://iaian7.com/webcode/mediaboxAdvanced):
mediaboxAdvanced 1.3.4
(updated December 3rd, 2010) There seem to be some errors in Internet Explorer 8 when using version 1.3.4b. Until I get a chance to test things out and fix the bugs, you may be better off with version 1.2.5, listed under “older versions” – be sure to download all the pieces, as installation needs images as well!
so we will wait for an fix for it.
regards 810
regards 810
15 years 8 months ago #85509
by audisport
Replied by audisport on topic Re: IE8 problems
Thanks for this reply 810! Does this fix the problem? If yes, how to change the version of the mediabox and is there other issue which could appear by changing the version?
Thanks a lot!
Thanks a lot!
15 years 8 months ago #85514
by 810
i can't test it, i don't have the problem, you can try this:
extract the mediaboxAdv.js file to: \components\com_kunena\js\mediaboxadvanced\js
extract the css file (choose white or black) to :components\com_kunena\js\mediaboxadvanced\css and rename the file to: mediaboxAdv.css
then clear your internet cache and try again.
regards 810
regards 810
The following user(s) said Thank You: audisport
Time to create page: 0.778 seconds
