- Thank you received: 1
Merged [Resolved] [Merged topic] Blurred, blurry, fuzzy, text in category headers (text-shadow)
On a side note - Safari does come with a Developers menu which can be enabled in preferences. I was able to use it do locate the file that I needed to adjust.
james
Check out My online community. Once you stop by you will be hooked. www.JameZtown.com
Are you able to use something like Firebug? Or if you happen to be on a Mac, you can enable the developer menu in Safari, to do similar things. This would allow you to pinpoint the file, and indeed the piece of code, which you need to remove/alter.
I didn't take note of exactly what I did because I thought it wouldn't be consisted with other templates.
If you post up a link to your site, or PM it to me, I could take a look and see if I can work it out.
I don't have firebug, but I saw somewhere google chrome has something similar built in. Where?
The link is www.JameZtown.com but I guess it will only be blurry for some people.
Weird.......
- 9themestore
- Premium Member
Open the www.jameztown.com/templates/siteground-j16-3/css/template.css file and go to about line 200. Delete the line
I hope it work.
You could also just change the Hex code if you fancied changing the shadow to a different colour. However, I found on my site that it also change things elsewhere and I couldn't find a colour that would work throughout, so I just removed it.
Also worth noting, if you change to a different template, you may have to change it's template.css file again, but at least you'll know how to do it now.
:woohoo:
