Question Customizing image buttons
But I'm having some slight problems understanding the ccs behind the sprites, I've made my own sprite, gotten the buttons where I want them, but then there's more parts of the sprite showing that I absolutely don't want there!
An image says more than a thousand words I guess;
So I guess you see my problem, how do I get rid of the not wanted parts?
As an example the ccs for the Mark all forums read is as far as I can tell only this part;
#Kunena .kbuttonuser span.markread{background-position:0 -331px;width:186px;}
so why does two other images "interfer" with the "Mark all forums read" image?
As you understand, my knowledge is lacking in these terms
And also, which file do I edit to remove the text parts hovering over my buttons?
And also; There is no separate icon for the Quick reply button, where and what do I edit to add mine?
Thanks for your time!
My problems are that I have more parts of the sprite showing then what I want and I can't really see the logic in why the parts show. If you look at the image above, my middle button there (The Mark all topics read" button) has two parts of my Online button as well, one below and one hover over at the left side of the button. It is also below my subscribe button in that example.
Plus I can't seem to find the file that holds the html so I can remove the txt parts hovering over my buttons either. Can you point me in the right direction?
And then, last, how to or where to make the "Quick reply" button from my sprite. I think I might be able to figure this one out though, but I've been banging my head for hours and hours on the earlier mentioned issues so I haven't gotten around to try it out yet
But to my request about what file to edit to remove the text above the buttons, do you know where this might be?
Ah well, never mind
If pleased with the default template settings kunena is an ace component, but it's living hell trying to customize it so I'm going back to phpbb3.
Thanks for your time though.
