- Thank you received: 1
Question Layout problems:
#2. Search text "Also search in child forums" displays vertical. Not sure whats happening here. Thank you for any advice.
Problem 2 only occurs in IE which I am using version 7 of
www.jvbu.com/index.php?option=com_kunena...nc=search&Itemid=144
jvbu.com
JomSocial version: 2.0.4
Joomla! version: 1.5.22
PHP version 5.2.x
MySQL version 5.0.x:
Webserver version 2.2.15
Joomla! template used: Tachyon (RocketThemes) with Gantry Framework
JomSocial template used: default
JoomXi: XIUS 2.5.358
Kunena 1.6.2
regards 810
You are searching on the old version kunena 1.5.
Its very easy on k1.6. Go to: backend - menus - kunenamenu - And disable the options that you don't want.
regards 810
