Kunena 7.0.8 Released
Question javascript:PasteQ
15 years 1 month ago #101419 by AlexSmok
javascript:PasteQ was created by AlexSmok
Does the kunena software analog pasteQ as in IP.Board.
I would like to quotes the selected areas and posts are not everything.
15 years 1 month ago #101421 by sozzled
Replied by sozzled on topic Re: javascript:PasteQ
AlexSmok wrote: Does the kunena software analog pasteQ as in IP.Board.
Short answer: no
AlexSmok wrote: I would like to quotes the selected areas and posts are not everything
What seems to be the problem?
15 years 1 month ago #101423 by AlexSmok
Replied by AlexSmok on topic Re: javascript:PasteQ
Yes, the problem for users. They are already used in other forums to do so. Cite all, and then cut out too much and do not want to resent. And they're right. Why do hard when you can easily.
15 years 1 month ago #101426 by sozzled
This is the BBcode I used to reply to your last message:
[quote="AlexSmok" post=101419]Does the kunena software analog pasteQ as in IP.Board.[/quote]Short answer: no [quote="AlexSmok" post=101419]I would like to quotes the selected areas and posts are not everything[/quote]What seems to be the problem?
Explain to your users how they can use BBcode and I think your problems will largely go away.
15 years 1 month ago #101434 by AlexSmok
BBCode is not suitable. They do not make it easy to reply to messages.
That would be comfortable and have the other board software. Read the message, highlight the text, clicked "quote selection." I read the following message. Highlighted, pressed. And so on.
Quotes came in the form of an answer, where I finished writing your message. And clicked "send" button.
We must use the best ideas.
15 years 1 month ago #101439 by sozzled
AlexSmok wrote: BBCode is not suitable.
In that case, good luck to you. I don't think there's anything more that we can do about this problem that your users are having. The fix for the problem is either to educate your users better, or to go back to IP.Board which they seem to be more comfortable with.
Time to create page: 0.218 seconds
