Question [Merged topic] Displaying images side by side in Kunena
14 years 10 months ago #100650 by Mark0100
Replied by Mark0100 on topic Aw: Re: Signatur Problems
But this is not an acceptable solution. Normal users can´t do it.
Gruß Mark
Pickup-Wohnkabinen-Forum Kunena 4.0.7
Chevy-Forum Kunena 3.0.8
14 years 10 months ago #100653 by sozzled
You don't need any special privileges or permissions to do this. You just need to explain the technique to your users.
Over the past 2½ years that Kunena has existed, it seems that these "side-by-side" image display issues surface, disappear and then resurface again. The problem wasn't there in K 1.6.3 but now it's back again. That's unfortunate.
In my opinion, I agree with you that images should be rendered side-by-side, and that behaviour should not change from one version of Kunena to the next. We agree that this issue is one that needs to be addressed and it should be addressed in a simpler manner than by using a "table" construct. Having said that, I do not know how to resolve this issue for K 1.6.4 except than by working around the issue as I have demonstrated. If this approach is unsustainable in your environment then you have my understanding but I don't have a technical solution for you.
This is something that needs further investigation and resolution for a future release of Kunena. In the meantime, perhaps someone else in the community has found a technical solution and they might like to share their solution with the rest of the community.
14 years 10 months ago #100654 by Bob Britt
Mark0100 wrote: But this is not an acceptable solution. Normal users can´t do it.
You are right, and what I don't understand is the images were rendering side by side prior to a site reload I had to do. I don't recall making any changes to make them render side by side, it just worked, now it don't.
14 years 10 months ago - 14 years 10 months ago #100992 by iLucato
Hi folks, when posting an TEXT + IMAGE + TEXT or URL + IMG + TEXT, I'd like that IMG bbcode would keep in the same line, but it jumps a line. Is there some way to avoid it?
Example:
blablablabla blablabla
As you see above, all was typed in one line and I'd like to show it in one line, but the BBCODE or the IMG tag on it seems to automatically jumps a line. So, how to make it all to show as one line?
Last edit: 14 years 10 months ago by iLucato.
14 years 10 months ago #100999 by sozzled
14 years 9 months ago #101200 by Bob Britt
That's not what we were doing prior, I can assure you.
Time to create page: 0.743 seconds
