Thanks!
Shawn
For clarification, my BBCode/BoardCode bar was not showing up.
- Jiminimonka
- Elite Member
- YBAS!
shawneo wrote: i have tried everything listed here! still i have a non functioning board code..uhhh. Would anyone like to login to the admin of my site and take a look. im close to just going with another forum component.
Thanks!
Shawn
You have not actually stated what you problem is at all.
Please read Please read first What information should I include when I ask for help (including how to post my configuration report)? and post with your configuration report.
Also can you please detail exactly what the problem you are having is.
Once this is disabled as well as disabling the "System - Mootools Upgrade" plugin I had my BBcode/Boardcode fully functional!
It should also be noted that I use the Rocket Theme template Crystalline.
Hope this fix helps someone else running into a similar issue!
Thanks again Michael for showing me how to troubleshoot these issues. It was a pleasure learning from your many years of experience.
Cheers,
Shawn
i need some help, so, i gonna be as more clear as possible!
i'm running a site on joomla 1.5.X and use the latest kunena components for the forum!
i use kunena profile when you click on username link and it work!
but i have a problem, i'm using another extensions like udeim for private message, karma and alphauser points that appear to work properly in the profile, when user want to edit profile (including my own profile as administrator in the front end, the field for change dont appear, also for signature!
i'd like to know if someone already face with this problem, what can i do? is the problem because of another components that have profile options also?
in backend, not all field are avaible to edit user details, simply status, name and signature!
thanks in advance!
url of my forum is golgennet.com/index.php/gforums
- Jiminimonka
- Elite Member
- YBAS!
Please read Guide to posting questions when asking for support at the top of this category section, and post your configuration report.
Thanks.
Please read msg #1 in this topic for the answer to your question. Your problem is caused by a Javascript libary conflict that is interfering with Joomla (which, in turn, stops Kunena from working). You need to fix the cause of that problem and then Kunena will work for you.
