Question Collapse, expand and Emoticons dont work
15 years 8 months ago #61635
Replied by sozzled on topic Re: Collapse, expand and Emoticons dont work
Well, I wouldn't go so far as to say that none of those disabled functions isn't responsible. I was reading, last night, about some of those JCE utilities (including the jcemediabox) and, unless you really, really need them I would put them high on my list of suspicious items.
There's another one I saw, too, that we haven't got yet: gkmemovie. Might be worth looking at that, too. Looks like that module/plugin loads another 3 .js libraries that I could tell.
The following user(s) said Thank You: Fremesa
The topic has been locked.
15 years 8 months ago #61637
by Fremesa
Replied by Fremesa on topic Re: Collapse, expand and Emoticons dont work
cufon I disabled, but domready_fix.js gk.script.js I dont find. but i disable all templaste opcion... and nothin happen.
15 years 8 months ago #61639
by fxstein
Replied by fxstein on topic Re: Collapse, expand and Emoticons dont work
Those scripts are most likely in the html of the template. Go to the Joomla template manager and check out the html file. It will have multiple includes for js in there.
Hope this helps!
Hope this helps!
15 years 8 months ago #61640
by Fremesa
Well... i goint to test memovie in my localhost... couse i made many change to my template... and nothing work fine... I goint to test if its the template or shome other think and i posted here de problem solved.
Thank You for all... read you later!!
15 years 8 months ago #61665
by Fremesa
The installation and provide some of the themplaste of Gavick and other JXTC and I had the same problem. In one I had not ...
From Gavick not operate any, available from people in a clean installation of themplaste memovie, Quay and the last of them cherry desing ... and might provide in Game JXTC and one that if it worked ...
I recommend that people talk Gavick.com to see what the problem between Kunene and his templastes.
If you somehow find the problem, respondanme this post to fix it, because my users use a lot of forums and could not go to the forum with such problems, since there is no second chance to make the first impression.
Thanks for everything!
15 years 8 months ago - 15 years 8 months ago #61666
by Fremesa
Otra cosa, con no hay problema.
Another thing, with kunena 1.5.12 there is no problem
Last edit: 15 years 8 months ago by Fremesa.
Time to create page: 0.244 seconds
