Question Remove login/logout and register links in Kunena
16 years 10 months ago - 16 years 10 months ago #25748 by sozzled
This forum is asked the question many times: how can I remove the login, logout, register and lost password links in Kunena? This is of particular interest to those who have alternative ways of managing these functions but who still want to keep the other features in the Kunena "profilebox". B)
The solution lies in modifying the file ../components/com_kunena/template/default/plugin/profilebox/profilebox.php. To save people the trouble, I am including the modified [K 1.5.4] source code here .
Attachment profilebox.txt not found
The effects of the changes are shown in the two images that follow:
(a) before login:
(b) after login:
Last edit: 16 years 10 months ago by sozzled.
16 years 9 months ago #26895 by David Boggitt
Will this code be the same for version 1.5.5 and could I please beg the developers to add the option to disable this line (but keep the 'Welcome' line) in the admin side.
Many thanks,
Dave.
16 years 1 month ago - 16 years 1 month ago #45597 by fishing_in_israel
(a) before login:
(b) after login:
This looks like the solution to my needs :)
Is it compatible with Kunena 1.5.11 ?
I just edited the file: components/com_kunena/template/default/plugin/profilebox/profilebox.php like so:
Overwrite (lines 194 to 200):
<br/> <?php echo _PROFILEBOX_PLEASE; ?>
<a href = "<?php echo $loginlink;?>"><?php echo _PROFILEBOX_LOGIN; ?></a> <?php echo _PROFILEBOX_OR; ?> <a href = "<?php echo $registerlink;?>"><?php echo _PROFILEBOX_REGISTER; ?></a>.
&nbsp;&nbsp;
<a href = "<?php echo $lostpasslink;?>"><?php echo _PROFILEBOX_LOST_PASSWORD; ?></a>
with:
<br/> <?php echo _PROFILEBOX_PLEASE; ?> <?php echo _PROFILEBOX_LOGIN; ?> <?php echo _PROFILEBOX_OR; ?> <?php echo _PROFILEBOX_REGISTER; ?>.
Basically it removes the hyperlinks.
And to remove to 'Logout' link:
Remove from line 139:
| <a href = "<?php echo $logoutlink;?>"><?php echo _PROFILEBOX_LOGOUT; ?></a>
I tested it on a local install just to make sure it works.
Could someone more knowledgeable than me confirm that this is OK.....
Last edit: 16 years 1 month ago by fishing_in_israel. Reason: typo
15 years 11 months ago #50851 by Hinson
I have a similar but different question. I don't want to remove the links, but I do want to change the wording from "Please Login or Register" to Please Login or Register to view forum contents.
I'm doing this in hopes that more 'guests' will be encouraged to register without having to allow them access to the contents of the forum.
15 years 11 months ago - 15 years 11 months ago #50852 by Hinson
Another question: I just realized that I neglected to check the 'subscribe' box and it cannot be done via 'edit.' Is there any way to set the default to subscribe and have the poster UNcheck if s/he doesn't want email notifications?
Last edit: 15 years 11 months ago by sozzled. Reason: Changed subject to improve search relevance
15 years 11 months ago #50861 by sozzled
Yes, that's a good way of rephrasing what I wrote 10 months ago. The idea is still similar (even if other things have changed between K 1.5.4 and K 1.5.12): you need to edit ../components/com_kunena/template/default/plugin/profilebox/profilebox.php and remove the hyperlinks surrounding the text strings that translate as "login" and "register".
Time to create page: 0.368 seconds
