Question [Topic archived by moderator - assumed resolved] CAPTCHA problem
16 years 2 months ago - 16 years 1 month ago #44690 by rojo
Hi!
Whenever I'm shown the CAPTCHA code it is an non-exsting image. In IE it appears as a red cross and in FF it doesn't appear at all.
In the HTML-source code the image src is listed as:
...path.../index.php?option=com_kunena&func=showcaptcha
Opening that URL in the browser displays this (faulty syntax?):
ÿØÿà�JFIF������ÿþ�>CREATOR: gd-jpeg v1.0 (using IJG JPEG v62), default quality ÿÛ�C� $.' ",#(7),01444'9=82<.342ÿÛ�C 2!!22222222222222222222222222222222222222222222222222ÿÀ�<and so on...>
What's wrong??!
Last edit: 16 years 1 month ago by sozzled. Reason: Topic closed
16 years 2 months ago - 16 years 2 months ago #44691 by Cerberus
Replied by Cerberus on topic Re: CAPTCHA problem
captha has never worked on K.1.5x series of kunena, hopefully they will have fixed that in K1.6 when its released :)
EDIT: there are captha solutions availible on JED joomla extensions directory that can be used for registrations though :) if you require
personaly i dont use captha i use registration vaildator 2 from the JED site :) so then i can block ips, ip ranges and domains from registering at all (eg mail.ru) can not be registered on my website :)
Last edit: 16 years 2 months ago by Cerberus.
16 years 2 months ago - 16 years 2 months ago #44699 by @quila
Replied by @quila on topic Re: CAPTCHA problem
@rojo
In K1.5 exist captha system but show only if you are using forum for Public Read/Write.
What is your configuration for Public Read/Write option??
P.S: url should be ..path.../index2.php?option=com_kunena&func=showcaptcha
Last edit: 16 years 2 months ago by @quila.
16 years 2 months ago #44777 by rojo
Replied by rojo on topic Re: CAPTCHA problem
Public read/write is set to yes.
I've installed the latest Kunena version. Why would the path be wrong? And how should I fix it? Besides the URL clearly shows some kind of jpeg-signature. Why is the image faulty?
16 years 2 months ago - 16 years 2 months ago #44780 by @quila
Well, as you can see on the image attached the captcha works well with clean install of K1.5.9.
You have conflict with some plugin installed which change output of your url. Try disabling one at time and look if change something. If you are using SEF/SEO try to disable to see if problem persist.
16 years 2 months ago - 16 years 2 months ago #44845 by sozzled
Replied by sozzled on topic Re: CAPTCHA problem
What version image processor do you have installed with your Joomla website?
Time to create page: 0.339 seconds
