Question latest posts not visible, does not create 3rd page
14 years 10 months ago #101536 by kboese
we have a protected area on our website www.kspworldtour.com on which our riders can exchange ideas and feedback. One of the topics has received quite a bit of interest and the problem is that if a rider posts a reply for some reason it is not visible... I think it is because the first 2 pages are full and for some reason no 3rd page is created, not leaving any room for further posts. Unfortunately I am really joomla and coding dumb and would really need help with this.
thanks a lot, K.Boese
14 years 10 months ago - 14 years 10 months ago #101537 by sozzled
G'day, kboese, and welcome to Kunena.
You have posted your question in the K 1.5 Support category. Although there is some support for K 1.5 we may have to remind people to choose carefully the category in which they post their questions to ensure that we're not confusing Kunena 1.5 and Joomla 1.5. If, indeed, your question relates to K 1.5.x, we ask you to please read K 1.5.x Support: Please read this first. .
After spending 10 minutes or more, I was able to discover that you are using K 1.5.11. It would have saved our time if you had indicated this when you posted your question.
K 1.5.11 is not supported any more. You should be using at least K 1.5.14 but it would be even better if you upgraded from K 1.5.11 to K 1.6.4 which you can do if you follow the K 1.6 Upgrade Guide .
We are aware that there are many unsolvable issues involved K 1.5.x and your case may fall into that category. This is why we recommend that people use the opportunity to make the change to K 1.6 as soon as possible.
I don't know why you are having the issues you describe but it might be worthwhile enabling Joomla debug mode to see if there are any errors being generated that you are unaware of. This may help in the short term. The longer term solution is, as we have continued to encourage everyone in this community, upgrade to K 1.6.4 as soon as you possibly can.
I hope this helps.
Last edit: 14 years 10 months ago by sozzled.
The following user(s) said Thank You: kboese
14 years 10 months ago #101680 by kboese
Thanks so much for that... Kunena came with the template and I am not sure why they had such an old version on a relatively new template... Thanks a lot for your help and the upgrade seems to have worked the trick.
Best for now,
Kristin
Time to create page: 0.222 seconds
