Question RocketTheme template causes problems with displaying text in [code]
  • lalakios
  • lalakios's Avatar Topic Author
  • New Member
  • New Member
15 years 11 months ago - 15 years 11 months ago #51819 by lalakios
Hello all! i need some help with bbcode please...
When i create a new post and i use bbcode,the text in the code does not display correctly..
It has a white color,so no one can see it because the background color is just the same!
HERE I WRITE MY CODE AND IT SEEMS WHITE..
any ideas to fix the colors? i use the default kunena template..no changes at all.....
Thank you!
Last edit: 15 years 11 months ago by sozzled. Reason: Changed subject to improve search relevance
15 years 11 months ago #51821 by sozzled
If you've seen K 1.5.x Support: Please read this first then you can probably anticipate the series of questions that I'm going to ask you:
What makes you believe that this is a Kunena support problem and not an issue with your Joomla template?
What version of Kunena are you using?
What Kunena template are you using?
What version of Joomla are you using?
What Joomla site template are you using?
Which specific BBcode tag or tags generate the white-on-white symptoms?
Can you provide a screenshot to illustrate your problem or, even better, can you provide the URL of your website where we can see this problem for ourselves, please?
Thank you. :)
  • lalakios
  • New Member
  • New Member
15 years 11 months ago - 15 years 11 months ago #51824 by lalakios
Replied by lalakios on topic Re: text in bbcode does not display correctly
ooops...I;m really sorry.........should give more info!
Well,the url is www.athlug.gr
I use the dominion template for joomla 1.5.18,and kunena 1.5.11 (default_ex template)
I tried to use the code at the right of the quote symbol...
I am not sure that joomla causes this...or kunena..............
In any case,you can test it or see in my forum :fun park: test
Hope i was clear this time...:)
Last edit: 15 years 11 months ago by lalakios.
15 years 11 months ago - 15 years 11 months ago #51831 by sozzled
Let me see if I understand you correctly: you see white-on-white when you post text contained in "code" tags, is that right? :dry:
To reproduce what is happening, can you please provide us with an account and password to test. When you reply, would you please enclose the account/password information in the new "confidential" tags (that way, only moderators and administrators at this website can see the information) like this, for example
[confidential]Account: test Password: test[/confidential]
I'm almost 100% certain that it's your website template that is causing the problem. If it Kunena was causing the problem then you would see the same problem here at this website, wouldn't you?
  • lalakios
  • New Member
  • New Member
15 years 11 months ago - 15 years 11 months ago #51834 by lalakios
oh,well...lets try it....
Here is the information...
You may log in at once....it;s activated already!
Thank you by the way for your help...!:)
15 years 11 months ago #51850 by sozzled
The problem lies at line 258 of the file ../templates/rt_dominion_j15/css/style2.css
Change from
.rok-comment-entry .comment-body, .bodylevel-high code {
color:#FFFFFF;
To
.rok-comment-entry .comment-body, .bodylevel-high {
color:#FFFFFF;
This will fix things for Kunena. I can't advise you how this will affect your RocketTheme template, however.
The following user(s) said Thank You: fxstein, lalakios
Time to create page: 0.249 seconds
