Question RANK NAME and NUMBER OF POSTS
16 years 9 months ago #27619 by kerios83
Hi i got a little problem with RANK NAME and NUMBER OF POSTS. I want the RANK NAME to disappear (im using default_ex kunena template) but when i change code in css div.viewcover {like... display:none;} NUMBER OF POSTS also disappear and that is something i dont want.
Is there any solution to get rid of RANK NAME (but keept it's image !) and propertly display a NUMBER OF POSTS.
I prefer css code change cause im don't know any php :unsure:
ahhhh i using kunena 1.5.3 now i see there is a new version so im gona update it immediately but i think in 1.5.15 i will have still the same problem, corect me if im wrong.
Kunena ROX!
16 years 9 months ago #27622 by Matias
Rank can be found from components/com_kunena/template/default_ex/message.php around line 224. Just comment it out like this:
// echo $msg_userrank;
16 years 9 months ago #27796 by kerios83
Ty for reply i will check this.
16 years 8 months ago #28871 by kerios83
Yep it works ! If want to get rid of user rank but not user rank image u need to delete:
<div class = "viewcover">
<?php
if (isset($msg_userrank)) {
echo $msg_userrank;
</div>
in components/com_kunena/template/YOUR KUMENA TEMPLATE/message.php around line 224.
THX matias !
16 years 8 months ago #28995 by dauf
can i make the rank name not appear only for 'special' user like admin, moderator etc??
16 years 8 months ago #28996 by dauf
Time to create page: 0.268 seconds
