Sticky migrating Joomla 1.x+Smf 1.x to Joomla 1.5+kunena Script
15 years 11 months ago #51038 by Dannymh
Sounds like you likely put some of the code outside of quotes.
Make sure all the Dbase user password etc are allnindividually in quotes.
I will try to finish this code this week too
15 years 11 months ago #51078 by brianfischer74
Thanks Dan. I didn't have quotes around anything.
I no longer get the error message. I'm definitely not doing something right. Basically it flashes to my homepage right away. I go into Kunena component and do the recount category stats and nothing has changed.
I'm using the orignial converter and the updated sm2k.php and not the one you updated. Only because it sounds like the old one kept passwords. Maybe it's an issue of me needing to use your updated one.
My situation though is that I was running community builder and the joomlahacks bridge so basically they were entering through CB. I'm trying to avoid messing this up somehow so that when I'm in Kunena they still have access with their CB stuff.
You mention that you are working on finishing it. With my above situation Is it just best to wait until your done working on your updated script?
Thanks for the help already. I don't know much about this script stuff so everyone posts in here have been helpful.
15 years 11 months ago - 15 years 11 months ago #51079 by Dannymh
yeah there is an infinite loop that overwrites and you end up with only a handful of users.
You need to make sure the SMF and Joomla tables are in the same table
Also Kunena and CB integrate so no problems there
As for waiting, yeah unless you dont mind the formatting.
Basically it converts the <br/> but incorrectly, i am thinking of taking that out and then running an SQL script to fix that
Last edit: 15 years 11 months ago by Dannymh.
15 years 11 months ago #51080 by brianfischer74
So if it only ends up with a handful of users if I understand correctly I can back up my users table before the script and put them back in after. What about the password thing. Since I'm integrating with CB would they still be able to use their existing or will they have to go the route mentioned in this thread of having to use a new password.
"Smf and joomla tables are in the same table". Are you meaning they need to be in the same database. I have them together in that but don't know if I'm supposed to do something else as far as "tables".
Thanks.
15 years 11 months ago #51081 by Dannymh
Sorry yeah meant the same database.
As for users no you cant really jsut backup the user table as you also need the ACL tables filled inc correctly.
Backup allt eh ACL and user tables and you will be right though.
better however to do this in aother installation
15 years 11 months ago #51082 by brianfischer74
I want to apologize for being a nob. The person that did all the smf is no longer helping and with the upgrade to joomla 1.5/community builder kunena sounds like it might be the best solution long term. Hoping to get there. Many thanks to you.
What are the ACL tables?
What do you mean by on another installation? Do a fresh Kunena install?
Time to create page: 0.281 seconds
