Question move users and posts from fireboard j1.0 to Kunena J1.5
thanks in advance
This is the general migration procedure I would use:
- On the original website, migrate and/or upgrade to Kunena 1.0.11. Alternatively, make a copy of this website using Joomlapack and perform the steps on the "copied" site.
- Install K 1.0.11 on your new Joomla 1.5 website
- Export the jos_fb* tables from your upgraded website and import them into your new site database
- Upgrade to K 1.5.4
Error
SQL query:
-- Dumping data for table `jos_comprofiler_lists`
INSERT INTO `jos_comprofiler_lists` ( `listid` , `title` , `description` , `published` , `default` , `usergroupids` , `useraccessgroupid` , `sortfields` , `filterfields` , `ordering` , `col1title` , `col1enabled` , `col1fields` , `col2title` , `col2enabled` , `col1captions` , `col2fields` , `col2captions` , `col3title` , `col3enabled` , `col3fields` , `col3captions` , `col4title` , `col4enabled` , `col4fields` , `col4captions` )
VALUES ( 2, 'Members List', 'my Description', 1, 1, '29, 18, 19, 20, 21, 30, 23, 24, 25', 18, '`username` ASC', NULL , 0, 'Image', 1, '29', 'Username', 1, 0, '42', 0, 'Other', 1, '26|*|28|*|27', 1, '', 0, '', 0 ) ;
MySQL said: Documentation
#1062 - Duplicate entry '2' for key 1
What does this mean??? Where to from here???
Any help greatly appreciated.
What is the current situation with your new J! 1.5.x website? What components (and what versions of those components) have you installed?
JForms 0.6 RC1
JomComment 3.0 Build 562
jPFChat 2.0.2
My Blog 3.0 Build 323
SimpleCalendar 0.7.9b
These components on both sites? You also have Community Builder V? installed on one or both sites, too?I have the following components:
JForms 0.6 RC1
jPFChat 2.0.2
My point is this: I was talking only about copying the SQL tables associated with Kunena. These tables (normally) have the prefix jos_fb_ ... you should not export other tables, particularly if you are running different versions of the components that work with them. In your earlier message you wrote:
jos_comprofiler_ tables are used by Community Builder. That is what the error message was about. You will need to upgrade CB to CB 1.2.1 when you upgrade to K 1.5.4!I followed the steps above and after importing the jos_fb files got the following error:
Error
SQL query:
I don't remember exactly the table names in K 1.0.8 (it was a long time ago). The K 1.5.4 tables are called:
jos_fb__announcement
jos_fb_attachments
jos_fb_categories
jos_fb_config
jos_fb_config_backup
jos_fb_discussbot
jos_fb_favorites
jos_fb_groups
jos_fb_messages
jos_fb_messages_text
jos_fb_moderation
jos_fb_ranks
jos_fb_sessions
jos_fb_smileys
jos_fb_subscriptions
jos_fb_users
jos_fb_version
jos_fb_whoisonline
Export whichever tables of the above-named that you have (and you may not have all of them, either) but only these!
I tried to unistall and try again and now get this error
Error
SQL query:
-- -- Dumping data for table `jos_fb_categories` -- INSERT INTO `jos_fb_categories` (`id`, `parent`, `name`, `cat_emoticon`, `locked`, `alert_admin`, `moderated`, `moderators`, `pub_access`, `pub_recurse`, `admin_access`, `admin_recurse`, `ordering`, `future2`, `published`, `checked_out`, `checked_out_time`, `review`, `hits`, `description`, `headerdesc`, `class_sfx`, `id_last_msg`, `numTopics`, `numPosts`, `time_last_msg`, `smf_category_id`, `smf_board_id`, `smf_board_parent_id`) VALUES (1, 2, 'Certificate III in Fitness', 0, 0, 0, 1, NULL, 18, 0, 25, 0, 2, 0, 1, 0, '0000-00-00 00:00:00', 0, 0, 'Discussions for all Certificate III in Fitness topics.', '', '', 169, 65, 91, 1247999089, 0, 0, 0), (2, 0, 'Certification Courses', 0, 0, 0, 1, NULL, 18, 0, 25, 0, 1, 0, 1, 0, '0000-00-00 00:00:00', 0, 0, '', '', '', 169, 73, 93, 1247999089, 0, 0, 0), (3, 2, 'Certificate IV in Fitness', 0, 0, 0, 1, NULL, 18, 0, 25, 0, 3, 0, 1, 0, '0000-00-00 00:00:00', 0, 0, 'Discussions for all Certificate [...]
#1054 - Unknown column 'smf_category_id' in 'field list'
- Make a copy of of your original Joomla 1.0.15 website using the appropriate version of Joomlapack.
- Using the copied version of the original website (I assume you know how to use Joomlapack and kickstart.php), completely remove Community Builder from your website.
- Upgrade from Fireboard to Kunena on the "copied" site. Please make sure you understand the upgrade process first! You have not stated what version of Fireboard you were using. Please search the forum for specific instructions on how to upgrade Fireboard (I suspect this is what has caused your latest problems). Please understand that I am only giving you a very general process description.
- Uninstall Fireboard; Kunena will not operate with Fireboard installed. Before doing anything else, make sure that your old Fireboard-now-Kunena website works properly!
- Uninstall any old versions of Kunena and Fireboard from your J! 1.5 site; if necessary, DROP all jos_fb* tables from your new J! 1.5 site. Kunena will not operate if Fireboard is installed. Install K 1.0.11 on your new Joomla 1.5 website.
- Install Community Builder 1.2.1 - do not install any other version of CB on your J 1.5 website! This is important!
- Ensure that your new J! 1.5 site now operates with Kunena 1.0.11. Make a Joomlapack backup of your new site.
- Export the jos_fb* tables from your upgraded website and import them into your new site database.
- Upgrade to K 1.5.4 on your new J! 1.5 website.
