Sticky K 1.5.12 - Known issues
15 years 11 months ago #50728
K 1.5.12 - Known issues was created by sozzled
Compatibility with user-customised or third-party-developed Kunena templates
As a general rule, many templates designed for previous versions of Kunena should work with the latest stable public release but this is only true to a limited extent. In general, many older templates fail to work with Kunena in unpredictable ways and these account for the major source of problems reported by users. Because of the way that Kunena 1.5 is designed, many bugfixes and improvements made to the Kunena component affect the way that templates interact and, more importantly, older templates may have code that is incompatible with the latest version. You should upgrade your template whenever new versions are released and - third-party developers should take special note - to apply bugfixes incorporated with latest default_ex theme.
Please make sure your template works in a test environment before upgrading your live site!
If you feel the features of the template that you currently using outweigh the need to upgrade to the latest stable release of Kunena, that is also your prerogative to remain at the version of Kunena that your template was designed for or until the developer of that template makes the necessary changes to it. However, if you encounter problems with the function of the outdated version of Kunena we are unable to assist beyond our general advice which is that you should upgrade to the latest stable release. The decision is yours.
The topic has been locked.
15 years 11 months ago #51065
Replied by sozzled on topic Re: K 1.5.12 - Known issues
Kunena 1.5.12 updates and replaces all previous versions of Kunena. All questions asked in the support or installation/upgrade categories concerning previous versions of Kunena have now been archived. Users who have problems with older versions of Kunena have two choices: to resolve their problems themselves or to upgrade to K 1.5.12 in an effort to resolve those problems.
Here is the list of issues and/or problems that we have discovered with K 1.5.12. This list is not 100% complete and it's not an official list, either:
- Search queries containing + - ' or " fails to return results.
- IE8: tagging of color does not work - in the Kunena message editor, the "colour picker" feature and URL insertion button do not properly insert the BBcode tags around selected text. This is a known issue with Internet Explorer.
15 years 10 months ago #53296
Userlist does not show any users - see
K 1.5.12: User list doesn't Show all.
15 years 10 months ago - 15 years 10 months ago #55106
When you insert more than 3 code lines, with code highlighting enabled, the last line does not appear (and there are some errors):
see Enable Code Highlighting Bug!
Last edit: 15 years 10 months ago by sozzled.
15 years 9 months ago #56695
Time to create page: 0.247 seconds
