Question Administrators Emailed with New Posts Despite Configuration Settings
15 years 4 months ago - 15 years 4 months ago #84953 by tomfuller2
EDIT: Set subscription box automatically set to Yes, to "No" Another clue: the email was sent to someone not set as a moderator or even a user in the forum and said in part "A new post has been made to a forum to which you have assigned as moderator in the OED Forums Forum"
Settings in configuration Email Administrators: No. When new posts are made to a forum, all site admins are emailed anyway.
Here are the settings, though site is behind a firewall so can't be viewed publically.
Legacy mode: Enabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 2M
Joomla default template details : rt_mediamogul_j15 | author: RocketTheme | version: 1.5.3 | creationdate: 12/30/07
Last edit: 15 years 4 months ago by tomfuller2.
15 years 4 months ago #84974 by sozzled
G'day, Tom, and welcome back. I remember an earlier question of yours New Posts get sent to all users as moderators (that you didn't reply to) in which we advised you to disable Legacy mode. I see that you have not acted on that advice and you are still using "legacy mode".
Our advice about "legacy mode" has changed. In the past we said that it was not a "good idea" (because, basically, "legacy mode" never really worked properly anyway) but, having seen examples where K 1.6 actually stops working because of legacy mode, the advisory now becomes a clear warning to users. Please read K 1.6 Technical Requirements .
I also see that you asked another question Illegal Characters in Global Data Error , which we responded to, but we have not heard from you on that issue either. And then there was the question you asked Bold, Italic, Poll Options Etc. Missing After Upgrade which, as in the other cases, we did not receive any confirmation that the information posted in those topics had helped you.
I wonder if you could help us out, please. Could you try to disable "legacy mode" and let us know if this fixes your problem ... and could you also post a note about each of the other topics I've mentioned to let us know how things turned out. Thanks :)
15 years 4 months ago #84976 by tomfuller2
Thank you for your quick reply. Apparently I had wrongly assumed I was subscribed to all the topics I had entered! I will do as you suggest and report back. I need to see if anything else on our site depends on legacy mode. And you are so right - with 1.6 there simply isn't a legacy mode so might as well work towards that!
Tom
15 years 2 months ago #89008 by tomfuller2
Legacy mode disabled, but still all administrators are emailed for all new posts, though setting is not to email them.
Here are new support details:
Legacy mode: Disabled | Joomla! SEF: Enabled | Joomla! SEF rewrite: Disabled | FTP layer: Enabled |
htaccess: Exists | PHP environment: Max execution time: 30 seconds | Max execution memory: 128M | Max file upload: 4M
15 years 2 months ago - 15 years 2 months ago #89041 by sozzled
Can I make a suggestion, please? Can I suggest that you read and use the advice given in Search Engine Optimization (SEO)
From your settings:
mailmod 1
mailadmin 0
Yes, in your case admins are mailed (even though you have explicitly set them to not receive emails) because you have enabled mail for moderators. Admins are automatically moderators.
Therefore the following combinations are valid:
mailmod = 0; mailadmin = 0 => no mail to admins
mailmod = 0; mailadmin = 1 => mail to admins
mailmod = 1; mailadmin = 0 => mail to admins (this is your case)
mailmod = 1; mailadmin = 1 => mail to admins
Last edit: 15 years 2 months ago by sozzled. Reason: Corrected broken link to SEO
15 years 2 months ago #89060 by tomfuller2
For this site I will just remove administrators and make them managers.
It might be a good feature to make a distinction between moderators and administrators.
The link the SEF information was broken for some reason.
Thanks again for an awesome component!
Tom
Time to create page: 0.294 seconds
