Question Hide BBCode [URL] for non registered users
So, are you saying that you don't want to hide (that is make invisible) these unspecified links. You just want to somehow "deactivate" them? Hey, I'm just replying to what you wrote, that's all. :SI am asking if there is something that can make it so if a Guest visits my website, and if they click on any post it will say "Please login to view this post" or "Please login to view this link".
Anyway, the answer is that you can't do this without modifying the code; there are (at least) two files that need to be changed to include a test to see if the person viewing the topic is logged-in or not. If the person is not a user, then don't generate the hyperlink.
This will result in another problem, however: how you prevent users guessing the URLs of your half-and-half restricted topics. Eventually these guests will figure out how to access the restricted-but-unrestricted messages directly. You won't be able to outsmart these types without adding some ACL protection that doesn't exist in Joomla 1.5.
Personally, I think we're over-engineering a solution to a non-problem. The easiest way out of this intellectual quagmire is to restrict certain categories to registered, logged-in users (this is what most people do) but that also means that those categories and the topics in them are hidden from guests.
Not easy to solve but at least we've clarified the question.
@quila wrote: Hi Milutin,
replace the file kunena.parser.phpwith this one attached. This hack hide all link in the post from unregistered user.components / com_kunena / lib /
Kunena 1.5.6
etusha wrotewill be good if u add this hack at KUNENA 1.5.7 ( by default )
yes will be good but there is a problem if someone want to show link.
In that case we need to have possibility to choose in the configuration, but this is for K1.6
Thanks quila for this example code i took a look and studdied it for a bit and then compared it to the current kunena 1.5.12 code and relised how you were making it invisible to unregistered users.
