Question Please Help: My forum Menu Tabs are Rounded and I do not want them to be
15 years 9 months ago #59770 by christian15213
It is screwing up my form because the tabs have the writing on the login form.
Thanks.:side:
15 years 9 months ago #59806 by Cerberus
#Kunena #ktab a { -moz-border-radius-topleft:5px; <--- remove me -moz-border-radius-topright:5px; <--- remove me background-color:#737373; border:0 none; display:block; float:left; margin:0; padding:0; text-decoration:none; }
15 years 9 months ago - 15 years 9 months ago #59822 by christian15213
The edit didn't work...
I just forgot that I didn't not have profile editor in CB published. as soon as I published it it broke again and gives me rounded tabs.
Last edit: 15 years 9 months ago by christian15213. Reason: edit didn't work
15 years 9 months ago #59828 by Cerberus
what file did you edit ??
kunena.forum.css
or
kunena.forum-min.css
or both ?
15 years 9 months ago #59832 by christian15213
I am bashing my head here trying to fix this. whenever, I set up Kunena >>> 1.6 with my CB 1.2.3 and set up the forum integration i.e. with Kunena I get an error with my Kunena Tabs. They become rounded. Now, this wouldn't be a problem too much except for the fact the tabs squeeze out the lettering and display it all over my login form.
So for example when the tab is suppsed to say Reply Topics... you only see the Reply and topics is white lettering displayed sloppily over my login form. ERRRRRRR... And I can't figure out a way to stop this or prevent this from happening.
I changed CSS in the template for Kunena removing
-moz-border-radius-topright: 5px; -moz-border-radius-topleft: 5px;
And that still did not work.
Whenever I have the CB plugin activated the tabs screw up. Bah humbug.
Just so you know... Whenever I use the Kunena integration setting to use CB for Login and Profile and user lists... and the CB plugin is disabled... the problem goes away... To me this seems to point somwhere directly to that CB plugin. but I may be wrong. Any help would be massively appreciated.
15 years 9 months ago #59860 by sozzled
*** Moderator's comment: Topics merged to resolve duplicated thread issues.
christian15213: If you start a topic on one issue you should stay with that topic. If you create multiple topics on the same issue it actually gets in the way of resolving your problem. ;)
Time to create page: 0.719 seconds
