Important Kunena 1.5 to 1.6 Language Conversion Tool
15 years 11 months ago #52469 by Matias
I finally got K1.5 to K1.6 language file conversion tool ready for production use.
You can use it either from CLI or from web browser. No parameters are needed, just right files in the right places and write permissions to your language directory.
Here is the directory structure that is needed to make the script to work:
en-GB/ admin/ en-GB.com_kunena.ini en-GB.com_kunena.install.ini site/ en-GB.com_kunena.ini xx-XX/ kunena.mylanguage.php yy-YY/ kunena.otherlanguage.php
Script will generate the same file structure to your own language as in en-GB.
It will include all the strings from en-GB files:
- Most of your translations will be filled in
- Untranslated entries will be commented out with the English strings in them
Please review all the translations against English strings. We have made a lot of adjustments into them
and this script does not compare content -- it just converts old format into new.
15 years 10 months ago #52601 by rinuccio sp
Hmmmm how to use this script? :blush: :blush: :blush:
15 years 10 months ago #52602 by xillibit
Like has wrote Matias you need to create this directory strucuture at the same level that kunena15to16-langconvert.php :
Create a directory for the language that you want convert, by example fr-FR for french and put in this directory the old language file designed for k1.5 :
fr-FR/ kunena.french.php
Then you have just to launch the kunena15to16-langconvert.php and the conversion will happen
15 years 10 months ago #52604 by etusha
you need LINUX OS :)
The following user(s) said Thank You: etusha
15 years 10 months ago #52614 by rinuccio sp
1.But this I can create this structure in any folder?
2.When the converter tools finished to convert, move the language files in their folders... correct?
3.Every time the version is updated I relaunch the tool to get new items to be converted in my language file? or add them manually?
15 years 10 months ago #52679 by Baze
I've used the conversion tool to create Macedonian language file from my 1.5.12 translation, everything went smooth so in the new file "mk-MK.com_kunena.ini" i assume i should uncomment (remove the ; before the new strings) the new translation lines and that's all right?
Time to create page: 0.306 seconds
