Idea SOLVED: NOT SOLVED: BBCode legend (Help) doesn't work
17 years 6 days ago #18927 by latino
Hi:
The legend is not working, my big problem were the tools. The BBCODE now works. We have same situation. But without the tools forum was useless, and you provided the fix!
Regards!
17 years 6 days ago #18928 by JComeskey
latino wrote:
Hi:
Regards!
OK, then you and I both share the same situation now. My guess is maybe an RT extension is causing js conflict. Other than Rok Candy, what RT extensions are you using?
17 years 6 days ago #18931 by latino
Hi:
I use rokweather, rokajaxsearch, rokstories, rokbox, roktabs, roktwiter, roknewspager, roknewsflash. The problem should be something system-wide. for the forum I dont have those modules active at it. So that makes it difficult to identify. I also run CB 1.2.1 so mayba a CB plugin could be the cause (if you have CB 1.2 too).
I tried disabling rokbox, rokcandy plugins. Nothing changed.
17 years 6 days ago #18943 by sozzled
Before going any further, to clarify the term tooltip, we are not using the commonly-used definition (i.e. the small yellow box that pops up when the mouse cursor hovers over a window element) - this is not an issue, I believe. We are discussing the behaviour of the Kunena message editor that uses Javascript to display alternative text in a yellow box below the toolbar.
I fairly convinced that Joomla has a bearing on this problem. Joomla 1.5.10 brought many security changes aimed at preventing badly-formed or malicious Javascript exploits. J! 1.5.11 has built on those foundations. Good thing too! B)
This is my personal experience of the problem:
  • Local PC development site: J! 1.5.7 website, K 1.0.10, CB 1.2.1, JEvent 1.5, JA_Purity template - BB tooltips work.
  • Beta test site: J! 1.5.7 website, K 1.0.10, CB 1.2.1, JA_Purity template - BB tooltips work.
  • Production site: J! 1.5.10 website, K 1.0.10, CB 1.2.1, govista template - BB tooltips did not work until I implemented the fix described in message #18844 .
This is a summary of what I know of JComeskey's experience:
  • Production site: J! 1.5.10 website, K 1.0.10, JEvent 1.something, RocketTheme template - BB tooltips does not work even after implementing the abovementioned fix; changing to rhuk_milkyway template has no effect either.
  • Secondary site: J! 1.5.10 website, K 1.0.8 - half the BB tooltips work but half of them don't. ( #18896 ); after upgrading to K 1.0.10 the behaviour is identical to the production site.
This is a summary of what I know of latino's experience:
  • Production site: J! 1.5.11 website, K 1.0.10, CB 1.2.1, RocketTheme Refraction template - neither BB code nor smiley worked until disabled RokCandy plugin; BB toolips do not work ( #18927 )
  • Secondary site: K 1.0.9 - BB toolips work. ( #18902 )
Have I summarised the important facts correctly? Do you see anything in common, anything I've overlooked?
17 years 6 days ago #18971 by JComeskey
I would add that I am using a Rockettheme template and some RT extensions at the secondary site too. So the RT stuff is definitely a common trait.
Both of my sites are also using Rokajaxsearch. That one caught my attention right away. However, I disabled it with no effect on the Kunena problem.
Also both of my sites are using CB 1.2. I have not upgraded to 1.2.1 yet, but it sounds like Latino has.
17 years 6 days ago #18977 by JComeskey
I don't think that this is related, but there is one other thing that I noticed at about the time that I upgraded to K1.0.10: At both of my sites, after submitting a post, I am no longer automatically redirected to the thread. I get stuck at the page that says 'Your message has been successfully posted'.
I looked for a configuration parameter on that, but did not find it. Am I just being ignorant? Is this a related issue? Is this a secondary issue?
Time to create page: 0.292 seconds
