Question [SOLVED] Upgrading Problems
- linuxgirlie
I upgraded my joomla to 1.5.12 and thought I would update my kunena forum to the 1.5 version as well as my joomla was running in legacy mode. But whenever I tried to upgrade kunena to 1.5 it failed so I have given up. I then downloaded 1.0.11 because the reason for update was so issues I was having with images/avatars being uploaded. This installed perfectly with no errors. But....
I noticed that my 'officer' users couldn't see the forums (including myself as an admin) that I had made the permissions to be viewed by publishers only. I checked joomla and they were all still there with the correct permissions, and I checked the user administration in kunena and they were all still listed there, but just couldn't see the forums with the special permissions.
I thought I would synconise the users as I had done with the old version but all I get is this:
So, I went back to the frontpage and noticed that kunena is saying:
So I have got a 1.0.11 installation that thinks its 1.5.4 :huh:
Is there anything I can do? I don't really want to start from scratch. Is it to do with the database? Can I delete anything out of it, or change anything? All of the front end seems fine.
Thanks,
Jo
What version of Joomla did you upgrade to 1.5.12 ?
- linuxgirlie
I was running Kunena 1.0.9
- linuxgirlie
- linuxgirlie
