- Thank you received: 2039
- Forum
- The Kunena Project
- Kunena Add-ons
- Kunena Latest (M)
- Kunena Latest (M) Archive
- Kunena Latest Module 3.0.1 not showing latest posts
Kunena 5.2.4 and Blue eagle 1.6.4 released (04 Apr 2021)
The Kunena team has announce the arrival of Kunena 5.2.4 [K 5.2.4] which is now available for download as a native Joomla extension for J! 3.9.x. This version addresses most of the issues that were discovered in K 5.2 and issues discovered during the development stages of K 5.2.4
REQUIREMENTS
Blue Eagle 1.6.x requires Kunena 5.2.x to work with, this template isn't designed to works with Bootstrap 3 and Bootstrap 4.
Solved Kunena Latest Module 3.0.1 not showing latest posts
Basic Options:
All/None: All/None
Category Filter: Hide Categories
Module Output: Latest Topics
Time Period: Since Last Visit
Change the category filter to "Show categories" and it should work.
My bad. Did not mean to lead you astray. I took over this site from another (as one does) and I was using my poor memory of how things work. On the previous J1.6.5/k1.7 site running on my test server it shows no posts when not logged in and then shows the most recent posts after you login. I was trying to reproduce that same behavior. Well... actually I was hoping that after the upgrade the behavior would be the same.I need to revise a few things. When I looked at your website the Kunena Latest module is displayed on the home page (without having to login first). You wrote:
That's not entirely true, is it? The module appears (although it outputs "No posts to display") even if you are not logged-in!I'm viewing the latest module when logged in, in fact that's the only time you see the output of this module.
The second problem is that, when we visit your forum, we see the message "There are no published categories in ." I replied to a similar question on this subject yesterday: Problems after migration from J! 1.5 .
For the second problem, I believe that was by design (also not my design), that you have to be logged in to see the forum.
The Kunena integration plugins may be installed - I did not say you should uninistall them, only disable them - but JomSocial and AlphaUserPoints components are not installed, are they? Pleass read the article Forum integration with other Joomla extensions... before I disable those two 'not installed' plugins I should point out that they are actually installed.
rich is on-the-ball, as always, and you should follow his advice!
You need to fix up your category permissions.
I read all those related posts but overlooked that trial.
Indeed: after changing that it now shows the posts when logged in.
The CSS is all jacked up but that will be the browser/template.
Funny that on the previous version the posts showed with that set to hide categories.
Thanks to you all for your very detailed help.
Now onto a different thread about why the Kunena menus don't show in the default view. I have read all the related posts on this too but after this I had better read them all again.
Well, this complicates the question relating to "Kunena Latest Module 3.0.1 not showing latest posts" by an order of magnitude, doesn't it? The way that people design who gets to see what whether they are logged-in to the site or not affects the kind of output that people will see (or not see) with the Kunena Latest module.For the second problem, I believe that was by design (also not my design), that you have to be logged in to see the forum.
Perhaps it's time to pause for a while, stop and consider who benefits from your forum. If you want to quarantine your forum so that only logged-in members have access to it, there are many simple ways you can achieve those things. If you want to use the Kunena Latest module as a kind of advertising medium for your home page, then you can do that, too. But you control who gets to use your site with how you choose to apply Joomla's ACLs and Kunena (and the Kunena Latest module, obviously) will honour those choices you make.
Thanks. It works like it did before now except for the menus not showing in the default logged in view. I will pass on your suggestions to the folks who make those decisions and they will tell me how they want things. Your assistance and that of your fellow moderators/developers has been great. You all went the extra mile. Thanks.
Forum Access
- Not Allowed: to create new topic.
- Not Allowed: to reply.
- Not Allowed: to edit your message.
- Forum
- Kunena Add-ons
- Kunena Latest (M)
