Kunena 6.2.6 released
Solved Pagination doesn't work
- Daviciacus
- Topic Author
- Junior Member
6 years 7 months ago #11
by Daviciacus
Replied by Daviciacus on topic Pagination doesn't work
Also, I tried the statistics recount in Kunena Tools, and did all the database tools in CB, cleared cache, and tried again, but still the same
6 years 7 months ago - 6 years 7 months ago #12
by rich
Example:
The menu item 1504 Forum linked to the defaultmenu=1505 and target is forum/index
The menu item 1513 Forum linked also to the defaultmenu=1505 but the targed is forumnl
You can't use sundry targets with the same menu ID.
But that's only a single example. You have more then one menu items with the same target, but different address.
You must repair the menu items, otherwise remain the problem.
Replied by rich on topic Pagination doesn't work
I checked your menus. The sort of the menu items are not correct.A few things I tried:
- Tried to create a new Kunena Category menu item, used that to load the forums and tried again, same result
Example:
Last edit: 6 years 7 months ago by rich.
- Daviciacus
- Topic Author
- Junior Member
6 years 7 months ago #13
by Daviciacus
I have corrected this now:
form -> id 1505
forumnl -> 1514
So now, for each language there is a different menu item for Kunena. Which is indeed a good thing.
But unfortunately, this still has not resolved the problem
form -> id 1505
forumnl -> 1514
- Daviciacus
- Topic Author
- Junior Member
6 years 7 months ago #14
by Daviciacus
Update: I have found the cause of the issue!
It was a module called "Article Module" (which places an article inside a module). When I don't publish that module on pages of Kunena, the pagination works again!
Time to create page: 0.395 seconds
