- Thank you received: 2516
Kunena 6.4.8 Released
Solved Banners between posts
It works.
But something happened with my REPLY window.
If you see in the attached image it is moved to the right.
Can you help please?
link to my forum: www.uzbaby.uz/forum/tabrik-va-qutloqlar/...gi-yil-tabrigi#71895
login:Pediatr
pswrd: 060606
And YES it works!
Thank you very much!!!
